Tank
9/11 - Never Forget
- Feb 19, 2016
- Above the Notches
- G0853
@Crumkz said, "This may be ambitious but since I mostly been lurking while waiting on my GT350 with tech pack I thought try to add something of value here. If this is useful maybe the mods can sticky this list.
The goal is to get a list of FRP and aftermarket GT350 parts all in one place with links. It can be used for anyone looking for replacement parts, mods or other S550 cars looking for GT350 style parts. Some of the parts are not on sale yet and not up on the FRP catalog but a few users here obtained info by calling around. In that case I added links to the thread.
So.......Im sure to be missing a lot please help fill this in!!"
September 2018: Thanks to all who've participated in this thread over the years. Looks like @Crumkz hasn’t been around in a few years so I offered to maintain this sticky and @Jarstang accepted.
Please note that most parts have an outside link to a vendor, including Ford Performance. Buyer beware; shop around for the best price and service through different vendors. Many members give AN-WBL and their parts department high marks. Also, check out the Sponsor Forum. (I am not affiliated with any vendor.)
Happy Wrenching,
Tank
2020 PART NUMBERS:
- https://performanceparts.ford.com/part/M-6766-A52 - Passenger side, self draining catch can.
Works on the 5.2 FPC with these https://performanceparts.ford.com/part/M-6067-M52S aluminum cam covers
2019 PART NUMBERS:
-Front Brake Rotors, Non-Drilled = KR3Z-1125-C & KR3Z-1125-D - @honeybadger
-Rear Brake Rotors, Non-Drilled = KR3Z 2C026 B - @btown93
-Revised Rear Spoiler = ??
-Factory Adjustable Strut Top Mounts (Thanks @Caballus !)
https://accessories.ford.com/kit-suspension-12374.html
Individual items within the kit follow:
KR3V-1813-AC: Adjustable Top Mount RH
KR3V-1814-AC: Adjustable Top Mount LH
W715135-S450: Mount to Body Fastener (6)
W7520215-S440: Mount to Strut Fastener (2)
W715932-S439: Strut to Knuckle Bolt (4)
W520517-S450: Strut to Knuckle Nut (4)
W712503-S440: Stabilizer Bar Link Upper Nut (2)
ENGINE / BOLT-ONS:
ENGINE
- 5.2L Voodoo Intake Manifold, M-9424-M52
- 5.2L Voodoo Cylinder Heads (RH), M-6049-M52
- 5.2L Voodoo Cylinder Heads (LH), M-6050-M52
- 5.2L Voodoo Radiator, M-8005-M8
- 5.2L Voodoo Cylinder Block, M-6010-M52
- JLT painted coil covers
- JLT Tune and CAI
- Lund Tune
- UPR Catch Can
- MagnaFlow Catback Exhaust
- Kooks Exhaust System
- GT350R Strut Tower Brace Kit (FP)
- GT350 upgraded valve springs
- GT350 ARP Head Studs
- 5.2L Voodoo Crankshaft, Part No. 6303
- FP Hood Struts, M-16826-MA
- GT350R strut tower brace at Ford Racing Parts or ANWBL GR3Z-6344210-BC
@50Deep
- Ford Performance GT 350 catch cans (passenger side unique) : RH: M-6766-A50, LH: M-6766-A50S
@bmarco
- GT350 R Front Coil Sping - FR3Z 5310 M
- GT350 R Rear Coil Spring - FR3Z 5560 P / T (left-right)
@buggy whip
-OEM R exhaust (catback): FR3Z-5230-N
-OEM non-R exhaust (catback): FR3Z-5230-M
@Bossing
2015-2018 MUSTANG SHELBY GT350 AIR FILTER - M-9601-G – same as the Airraid filter available at lower prices..
@FORDSTANGER
-Antigravity ATX-20-HD - Lose over 20lbs for your GT350/R. Thanks @Tomster
TRANSMISSION:
- FR3Z-7003-E – 2015/16 Base and Technology Package Transmission .(i.e. no internal pump for cooler)
- M-7000-M8S internal pump transmission & M-7095-M8S transmission cooler kit
for 2015/2016 Tech and Base GT350s @boss doc
PARTS FOR DIFFERENTIAL COOLER INSTALL (if you don't know, no need to ask :
- Track package diff cover - FR3Z-4033-B
- Differential Cooler Pump Harness Pigtail - 9U2Z-14S411-NA
- Differential cover temp sensor (track pack) - 9L8Z-6G004-E (Don't let the "Cylinder Head Sensor" description trick you up...)
- Differential Cooler Kit - M-4000-M8S for 2015/2016 Tech and Base GT350s @boss doc
Non OEM Option:
- Full Tilt Boogie Racing rear diff cooler kit
EXTERIOR:
- FP GT350 Exhaust Tips and Rear Valence, M-5230-M8SBV
- FP GT350R Front Splitter, FR3V-17D997-AE
- Anderson Composites GT350 Front Fascia
- Carbon Dynamics GT350 Front Fascia
- Anderson Composites GT350R Rear Spoiler
- C2C Carbon Fiber GT350R Rear Wing
- Carbon Dynamics GT350 Track Pack Spoiler
- FP GT350 Track Pack Rear Spoiler, GR3Z-6344210-BC
- GT350 Rear Diffuser Close Out Panel at Levittown
@racingandfishing
-Front Splitter non-R: FR3Z-17626-E
@Bossing
- R front grill with badge - FR3Z-8200-BB
- R rear tunnel panel with badge - FR3Z6342528BF
@zzj
- GT350 Carbon Black Radiator Grille w/ Snake Emblem OEM - FR3Z8200AB/ FR3V8200APIA02
- GT350R Radiator Grille Black Red Grill Emblem OEM - FR3Z-8200-BB/ FR3Z-8A224-BB
@HizliBullet
- Exhaust Valve Actuator FR3Z-5K245-A @Zitrosounds
-Looking for the half moon clips for your front splitter?
-OEM rear view cover and paint code. Thanks @Patio208
WHEELS/BRAKES:
- OEM Wheel and Tire Specs, thanks @RugbyRef
- Need4Speed GT350R Spec Wheels
- GT350R Brembo Red Calipers (Front - FR3Z 2B120-G / FR3Z 2B121-F; Rear - FR3Z 2552-F / FR3Z 2553-F)
- OEM GT350R Wheel Front - FR3Z-1007-S Rear - FR3Z-1007-R
- TPMS Sensor part number: FR3Z1A189-A (TPMS39) (315 MHz)
- M-1012-N Ford open lugs, black - all Mustangs 2015-2019
SUSPENSION:
- BMR Camber bolts PN# FC003
@Zitrosounds
-- GT350R rear sway bar ( FR3Z-5A772-E )
-- GT350R rear sway bar bushing ( F2GZ-5493-C ) **note: 2 bushings will be needed**
both courtesy of @dwalker
INTERIOR:
STEERING WHEEL
- Ford Performance 2015-2016 GT350R Steering Wheel Kit, M-3600-M350R
- Carbon Dynamics GT350R Styled Steering Wheel
- RPI Designs GT350 D Style Steering Wheel
-Beith Custom Steering Wheels - many models covered
- GT350 Shift Knob
SEATS
- GT350R Rear Seat Kit, M-63840-MS (NO LONGER AVAILABLE)
- GT350 Rear Seat Delete, Part #FR3Z 6360508-A
- Seatback Cover Assembly at FordPartGiant.com
@HizliBullet
ROLL BAR
- CoolTech Roll Bar for GT350/GT350R/GT - CoolTech announced they’re discontinuing this as of September 2018.
- Watson Racing Roll Bar
- Competition Motorsport Roll Bar
TOGGLE SWITCHES and USB Upgrade
- All sorts of custom designed toggle switches GT350 from Shapeways
- Upgrade USB hub, in console, for Apple Carplay - HU5Z-19A387-A
RACE PEDALS -
- Steeda at Amazon
- Steeda at CJ Pony Parts
- SPR
ACCESSORIES:
- GT350 Weathershield Style Vehicle Cover, FR3Z-19A412-E
- GT350 with Raised Spoiler, Weathershield Style Vehicle Cover, FR3Z-19A412-F
- Ford Transmission Air Scoop
@1Voodoo
-Zl1 Add-Ons Mustang 16-18 GT350 Splitter Guards
@havasu486
- Car cover/2016 Ford Mustang Cpe. Shelby GT350 - FR3J 19A412 EA (350R (FA))
@RNDT38 & @Action
- 2018 Shelby GT350 key fob - JR3V-15K601-JA - OE 164-R8187
@HizliBullet
MISCELLANEOUS PART NUMBERS FROM @TOMCATV8 AFTER A DEER RAN INTO HIS GT350
- Fuel label w/SHELBY GT350 FU5Z9A095C
- Tire information label DU5A-1532-AB
- Tire loading label 5U5A-1532-AA TLU
- RT Nameplate "GT350" FR3Z16098A
- Windshield FR3Z6303100E
- Roof molding nuts W703027S300
- RT Rocker molding w/SHELBY GT350 FR3Z6310176AB
- LT Rocker molding w/SHELBY GT350 FR3Z6310177AB
- Rocker molding rivets W718365S300
- RT Sill plate "Ford Performance" FR3Z6313208BA
- LT Sill plate "Ford Performance" FR3Z6313208BA
- RT Door shell FR3Z6320124A
- Back glass Ford FR3Z6342006A
- RT Qtr glass FR3Z6329710A
- LT Qtr glass FR3Z6329711A
- High mount lamp coupe DS7Z13A613C
- Stripe tape hood-rear black/white FR3Z6320000CP
MAINTENANCE ITEMS:
Part Numbers and Fluid Standards/Capacities (per '15/'16 Supplement) If someone wants to give me the '17/'18/'19..I'll add it here
- Oil Pan Drain Plug: FT4Z-6730-A
@KiLLeR2001
- Air filter- stock: Ford Part #: FA-1922
- Fuel filter: Ford Part #:FG- 1083
Changing the fuel filter at 30K mile intervals was a new maintenance item documented in the 2017 Supplemental Manual. No rationale provided.
- Spark plugs: Ford Part #:SP-519 / CYFS-12Y
- Battery: Ford Part #: 67R-390
- Oil Filter: Motorcraft FL-2069-ST (Ford Part # GR3Z 6731 A)- first gen spin on takes a 74mm 14 flute oil filter wrench. If someone wants to give me the cartridge number, I'll put it here.
- Engine Oil: 5W/50 -10 quarts Ford Standard WSS-M2C931-C
- Transmission Fluid: Motorcraft Mercon LV Ford Part # XT-10-QLVC), Ford standard: WSS-M2C938-A
- Engine Coolant: Motorcraft Orange Antifreeze/Coolant(Ford Part # VC-3DIL-B) (Ford standard: WSS-M97B44-D2)
- Rear Differential Fluid: Motorcraft SAE Premium Synthetic Hypoid Gear Lubricant (Ford Part # XY-75W85QL) (Ford Standard: WSS-M2C942-A)
- Rear Axle Friction Modifier: Motorcraft Additive Friction Modifier (Ford Part #: XL-3) (Ford Standard: EST-M2C118-A)
- Brake fluid: Capacity- Between MAX and MIN on reservoir, Motorcraft DOT 4 LV High Performance Motor Vehicle Brake Fluid (Ford Part #: PM-20), (Ford Standard: WSS-M6C65-A2 & ISO 4925 Class 6)
PARTS/TOOLS TO MAKE LIFE EASIER:
- Reverse Logic Female Threaded Lug Guide Tool - M14 X 1.5 - two can work but 3 makes life much easier...200 mm lengths are available too
- Caliperfexion Brake Caliper Studs
- FloTool 16 Quart Oil Drain Pan found at Wally World
- Motive 0109 Brake Bleeder
- @lenFeb, reports the CTEK US MULTI 3300 Battery Charger ihas been discontinued. The successor is CTEK 40-206 MXS 5.0-12 Volt Battery Charger
-Making a mess taking off your cartridge style oil filter or need a ,Belly Pan Trap Door, Oil Filter Guide, Oil Funnel & Oil Funnel Caps? Check out @pilotgore 's 3D Printed Oil Change Gear Back In Stock!
-FRACTION INCHES = DECIMAL INCHES = MM - Quick reference guide
Happy Wrenching,
Tank
2020 PART NUMBERS:
2019 PART NUMBERS:
-Gurney Flap = KR3V-44212-AC5G9Z Thanks @RugbyRef
-GT350 Cobra Puddle Lamps Thanks @slikk66-Factory Adjustable Strut Top Mounts (Thanks @Caballus !)
ENGINE / BOLT-ONS:
ENGINE
- JLT Tune and CAI
- Lund Tune
- UPR Catch Can
@50Deep
@bmarco
@buggy whip
@Bossing
@FORDSTANGER
TRANSMISSION:
Non OEM Option:
EXTERIOR:
@racingandfishing
@Bossing
@zzj
@HizliBullet
WHEELS/BRAKES:
SUSPENSION:
@Zitrosounds
INTERIOR:
STEERING WHEEL
- GT350 Shift Knob
SEATS
@HizliBullet
ROLL BAR
RACE PEDALS -
- Steeda at Amazon
- SPR
ACCESSORIES:
@1Voodoo
@havasu486
@RNDT38 & @Action
@HizliBullet
MAINTENANCE ITEMS:
@KiLLeR2001
Transmission Fluid (no cooler) 2.5 qt ( 2.4 L)
Transmission Fluid (with cooler) 3.3 qt ( 3.1 L)
Non-cooler 3.2 pints (1.5L)
With cooler 4.1 pints(1.9L)
Non-cooler 3.25 oz
With cooler 4.25 fl oz
- Stock non-R wheels fit over them just fine. (Please let me know if the R or other aftermarket wheels work.)
- WILL NOT work with the following wheels:
- Need4Speed 6GR
- Apex Racing
- SVE R350
- There’s NO guarantee any other aftermarket wheel will fit over them.
