GT350 OEM, Aftermarket and Maintenance Parts/Tools to Make Life Easier
Tank
Tank
9/11 - Never Forget
Above the Notches
G0853
Edited first post to add the 3D Printed Oil Change Apparatus Oil Filter Funnel from
newly anointed GOLD SPONSOR @pilotgore :rockon:
See the link at the bottom under the Parts to Make Your Life Easier section.
km1075
Chicago
2018 C63s, 2020 GT350 HEP
Anyone know the correct OEM oil filter part number? Mechanic today installed KU2Z-6731-A, previous dealers have installed KR3Z-6731-A. The latter is more expensive. Does that mean it's better? Will the cheaper model suffice, even if I take my GT350 for track days? I do change my oil often so maybe the less expensive one is OK? Thank you for your help.
The Chairman
South TX
‘09 GT500KR & ‘16 GT350 Track Pack & ‘20 GT500 HP
According to the system, that’s the correct (new) part number for GT350’s with that style filter. So you should be fine.
GTIIIL
Encinitas CA
2020 Shelby GT350
Are you referring to the Ford parts system? As I was on my way to buy a filter, I read this thread and I called the dealer to inquire. The KU2Z filter is also used in the F 150, where the KR2Z filter is for the Shelby GT 350 only? Are we sure they are the same filters? I’m confused...
km1075
Chicago
They are not the same filters. GT350 initially was offer with can style filter, then it switched to paper filter from 2017 to 2018, that is the KU filter. For 2019, the KR filter was introduced. It is an upgraded version of the KU filter. Either can be used but i am going to stick with the KR filter.
GTIIIL
Encinitas CA
2020 Shelby GT350
Well, I ended up buying the KR filter. I compared the two and just visually, it looks like the KU filter would probably come apart under the oil pressures seen in the voodoo motor. Don’t know that I would trust the KU myself, but I have no basis other than a visual comparison.
The Chairman
South TX
I don’t use either. I use the K&N filter: PS-7037:
buggy whip
ca
ford pinto, '16 GT350/OxFo/ Trac/Stripe delete
TPMS - 62 - 1X
P/N - FR 3 Z - 1A189 - C
315 Mz
$83.62 ea. !
Honey Badger posted his P/N is FR 3V - 1A 180 -AA
FR 3V - 1A 150 -AA
The parts guy said these are specific for GT350 only.
Tank
Tank
9/11 - Never Forget
Above the Notches
G0853
For linking to the front page under the Parts and Tools to Make Life Easier section.
