Car started SMOKING, then bucking a little, now wrench light...
Cgouzoulis
chris
None
Im concerned as well about the oil pressure in first pic. I see you were doing around 40ish, but cant see RPM. IMO, I think cruising at that speed you should be up around 90ish PSI
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
Looks like it's the transmission
Glad you figured out the source of the leak, Tom, but sorry about the leak and gearbox. HOPEFULLY, your dealer will do the right thing and replace it. The other Tom (@Tomster,) knows this car inside and out, (think the best tech in town,) and I for one would absolutely, positively follow his advice and demand a new one.
The relatively low "full" level of of the oil is SO much more important in this transmission than any others I know and because of that and, because you obviously lost a fairly large amount of it with the leak, I'm quite sure Tom is correct when he says the box is trashed.
Tomster
Beware of idiots
Tom
I still would like to know what's up with the oil. Who's been doing the oil changes? Did the OP verify oil level after service? If you've been running around with not enough oil in the engine, that may be trashed too. If a dealer did this, it's on them. If you did this, it's on the op.
So let's see, 18k for a trans, and 30k for an engine.
Tomster
Beware of idiots
Tom
Well the lack of a reply sort of says it all. This guy has some serious problems ahead of him.
My guess is someone changed the oil and didn't put enough back in. (1qt per cylinder rule maybe). I hope it was the dealer who did that and not the op.
tps7c
tps7c
Atlanta
Tom
2021 GT500
I just got back from work which is why I haven't been able to reply. To be honest, the dealer changed the oil before I purchased it, around 5k miles, and it now has about 11k. So yes I realize I'm a bit overdue and the oil change light came on recently, but the engine was running perfectly and I doubt I'd be able to drive it that hard on the backroads and not know it was short on oil. The engine was running in top form, no warnings, no high temps, no hesitations or going into limp mode.
Tomster
Beware of idiots
Tom
Did you ever check the oil level since it was changed? I hope it was a ford dealer.
Nickel
NC Twisties
www.instagram.com
Nick
2022 Mach 1 Handling Package TR3160 w/Recaros
I knew when I saw the title it would be DCT. This is why I didn't buy one, and why I didn't buy a 350, but love them both. I hope Ford gets it fixed for you.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
40mph at normal throttle % is probably like 2000rpm so that pressure seems fine.
As far as the mysterious dipstick reading, is the car just sitting at an angle? That would be my first guess, lol. There's no other way to get that result. If it were low it wouldn't show up on the stick at all, at least I would think.
SnowFox
Mn
Grabber
2022 GT, 2017 ECOboost, Saleen S351
pretty sure the DCTs are $20k
After having owned a Ford focus with a DCT as a commuter car. I've been scarred away from DCT's for life. Right turn on red was never a safe option.šŸ˜‚ They eventually lemoned the car.
18k fking hurts
Inthehighdesert
NM
Charlie
That was a getrag, the 500 is tremec. Not the same animals.
18k fking hurts
Bulldog9
NW Kentucky
2020 Bullitt, 2017 Tundra TRDPRO, 1976 Porsche 912
If I was a dealer, I'd have my techs check the threads............. Might be a good idea to delete this thread, especially those roasted tires.
Good Luck!
Bullittproof
New York
2023 Mustang GT Premium Fastback - Race Red !
is it possible that the oil level is below able to register BUT there is enough oil on the wall the diptube being transferred to the dipstick (which is not centered in the tube)? a long shot it but would fit the scenario.
Postal Bob
Long Island, NY
Bob
2019 Shelby GT350
As for the dipstick, I'm guessing the car is very low on oil. If it wasn't, then at least the lower hole of the dipstick should have oil in it. Guessing why only one side has oil showing, is that there's some oil in the dipstick tube, that rubbing off on the dipstick as you pull it out. The oil being on the bottom curve of the tube. The engine oil could be very low, but while driving, some splashes up the tube, and drips down onto the curved part.
Inthehighdesert
NM
Charlie
Why? The dealer gets paid to service the vehicle, not send techs on fishing expeditions. Iā€™m gonna ask my buddy thatā€™s a master tech for ford. He should have a doosie of a resonse for that.
Good Luck!
