Abnormal Camshaft Wear
Racin4ds
Ocala, FL
Donnie
2015 Mustang GT
There's no need to be snide. Besides actually being more complicated than your simplified example makes it, you don't run around all winter with an oil temp of 0C so they aren't the same even then.
Nope, but cold starts in any winter climate that 5wxx oil is flowing the same, rather its 5w20-5w30-5w40-5w50!
I wouldn't run anything less than a 30wt in these motors period! The thin crap was purely spec'd for CAFE reasons only and Fords arm being twisted for fleet MPG ratings at the expense of engine longevity. There is MANY reasons ford Back Spec'd to 5W30 in the later years of the Coyote and always stated 5W50 for any track use. Lets face it, most mustang owners run the heck out of these things on a daily basis!
LunarS550
LunarS550
Michigan
Garrett
2016 GT P1X ProCharger
Well stock cams are on national backorder with no ETA, so if I can’t track one down I’ll be getting comp NSR stage 2 blower cams. Bummer, would rather save $2k and stay stock.
While I’m in the motor I’ll be replacing all followers, adjusters, cam cap bolts (TTY), cam phaser bolts (TTY), as well as primary and secondary chains.
For the lube lovers, I’ll be going 5w50 motorcraft because Roush does with their kits.
Am I missing anything?
I Bleed Ford Blue
North East OHIO
yes, billet OPG's and CS. if your that far into it, do the pump gears and crank sprocket.
SheepDog
Colorado
Dax
Iconic Silver 2022 MACH 1 HP
You might try MMR.
https://www.modularmotorsportsracing.com/cart/index.php?main_page=product_info&products_id=1531
SheepDog
Colorado
Dax
LevittownFordParts
Worldwide
Benny
S550's!
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Tomato tomotto
The motorcraft oil shears down to a 40 weight very quickly.
But I get why you or anyone would want to run it. Ford won't ever deny warranty using Ford's oil.
LunarS550
LunarS550
Michigan
Garrett
You asked
I was referring to any TTY bolts I may have overlooked.
What do you recommend? Preferably not a $250 oil change
Warranty is long gone unfortunately lol. Figured being in a cold climate, frequent oil changes, and minimal yearly mileage that wouldn’t be a bad thing in my case.
K4fxd
NKY
If you want the best protection look for an oil that meets A3B4 euro spec. That spec is for wear protection where as all new oil specs are for emissions.
LunarS550
LunarS550
Michigan
Garrett
Driven FR50 seems like good stuff
