Post this on our forum and I'll reply thereThis is a long shot but maybe @Rolls *fingers crossed* could provide some information on the code.
Goto a shop you trust (if that even exits anymore) and put it on a high dollar scanner. Or unplug (one at a time) the ABS sensors and see if a new code come up. If they don't change, at least your narrowed it down-ish.Anyone on here able to give me some pointers? :( I’m getting so frustrated with this crap :(
We don't let anyone post unless they have purchased the software due to huge amounts of spam.I joined pcmtec, tried a few times to post a thread, after getting the ‘choose crosswalks’ and
‘Choose motorcycles’ 4 or 5 times and getting annoyed I gave up.
Ask @Rolls about the joining problem. I would try to get with him and if not I would try another pcm
We have a support portal if you wish you contact us https://support.pcmtec.com there instead. I thought you were a direct customer, not a B2C
Next time it dies and just cranks but doesn't start try unplugging the maf sensor and then starting it. You can drive without the maf sensor as long as you keep the rpms lower than like 2.5k and are easy on the throttle.More developments though, not been near the car for a couple of weeks so took it out today, cut out completely twice stopped in traffic at idle, turned over but wouldn’t start again for a few minutes then fired……no codes stored, I’m really at them end of my tether with this shit and need some pointers :(
Could this be throttle body releated?
Thanks, I’ll give that a go, not easy though, it usually happens when I’m in the middleNext time it dies and just cranks but doesn't start try unplugging the maf sensor and then starting it. You can drive without the maf sensor as long as you keep the rpms lower than like 2.5k and are easy on the throttle.
Not sure its really related to the issue but the ecu uses different calculations when it has no maf sensor to run the car. One time my tune was very off and for someone reason when the car was hot the car wouldn't start. Just a thought for if you get stuck again.
I’ve contacted Roland on pcmtec and asked about their software, if it can get to the bottom of this………I'm wondering if it's a fuel or spark issue. Faulty fuel pump? Have you tried to data log it? It might show what's happening right before it happens.
You could also buy their software and use it. Drive and data log and see if they can catch it in a log
I hope you get it fixed. I'm here for the long haul with ya.I’ve contacted Roland on pcmtec and asked about their software, if it can get to the bottom of this………
