u0401:82-08 Code and other issues, can you help me please?
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
ā“‡ā’¾ā’øā“€ā“Ž ā“ˆā“…ā’¶ā“ƒā’¾ā“ˆā’½
'17 S550
Nah,, I turn off all the nannies when I fire her up as well haha.
MarkM
MarkM
NI
I joined pcmtec, tried a few times to post a thread, after getting the ā€˜choose crosswalksā€™ and
ā€˜Choose motorcyclesā€™ 4 or 5 times and getting annoyed I gave up.
Anyone on here able to give me some pointers? :( Iā€™m getting so frustrated with this crap :(
DonnieO
Donnie
2017 mustang gt cs
Ask @Rolls about the joining problem. I would try to get with him and if not I would try another pcm
WildHorse
N/A or GO HOME
'17 S550
Goto a shop you trust (if that even exits anymore) and put it on a high dollar scanner. Or unplug (one at a time) the ABS sensors and see if a new code come up. If they don't change, at least your narrowed it down-ish.
Rolls
Gold Sponsor
www.pcmtec.com
Mustang 18 GT
We don't let anyone post unless they have purchased the software due to huge amounts of spam.
We have a support portal if you wish you contact us https://support.pcmtec.com there instead. I thought you were a direct customer, not a B2C
MarkM
MarkM
NI
Appologies for the late response, real life gets in the way sometimes :(
Iā€™ve raised a ticket on pcmtec and hopefully @Rolls can help me through this, as said, I donā€™t have anywhere left I can take it and Iā€™m on my own :(
More developments though, not been near the car for a couple of weeks so took it out today, cut out completely twice stopped in traffic at idle, turned over but wouldnā€™t start again for a few minutes then firedā€¦ā€¦no codes stored, Iā€™m really at them end of my tether with this shit and need some pointers :(
Could this be throttle body releated?
DonnieO
Donnie
2017 mustang gt cs
I'm wondering if it's a fuel or spark issue. Faulty fuel pump? Have you tried to data log it? It might show what's happening right before it happens.
You could also buy their software and use it. Drive and data log and see if they can catch it in a log
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
Next time it dies and just cranks but doesn't start try unplugging the maf sensor and then starting it. You can drive without the maf sensor as long as you keep the rpms lower than like 2.5k and are easy on the throttle.
Not sure its really related to the issue but the ecu uses different calculations when it has no maf sensor to run the car. One time my tune was very off and for someone reason when the car was hot the car wouldn't start. Just a thought for if you get stuck again.
MarkM
MarkM
NI
Thanks, Iā€™ll give that a go, not easy though, it usually happens when Iā€™m in the middle
Of the road and I scramble for my reader to see if thereā€™s a code, itā€™s so frustrating :(
MarkM
MarkM
NI
Iā€™ve contacted Roland on pcmtec and asked about their software, if it can get to the bottom of thisā€¦ā€¦ā€¦
DonnieO
Donnie
2017 mustang gt cs
I hope you get it fixed. I'm here for the long haul with ya.
MarkM
MarkM
NI
Ok, on my own again, @Rolls is a good guy who had the patience to have a few back and forths with me but ultimately canā€™t help.
The latest happening is another cut out at low speed, tbh the other times this happened Iā€™m not sure if this message appeared, but this time a yellow box appeared with instructions to start the car again, ignition off, brake pedal depressed etc.
I had a read though the manual and found the exact procedure under fuel pump shut off in the event of moderate accidentā€¦.
Could this shut off be my problem? Where is the physical shut off or does it use airbag sensors to kill the pump, if so where exactly are they?!
Iā€™d be grateful if anyone could give me any pointers, I almost traded it for a C63 this week but ultimately I realised I still want this big dumb thing!
