Rear coil spring isolators torn - 2019 Bullitt with very low mileage
NGOT8R
Adrian
2019 Bullitt
I just dropped the cradle on my 2019 Bullitt (with 8500 miles on the odometer) in preparation for installing BMR drag race springs and discovered that the top and bottom isolators for each spring are torn. It seems that the ends of the coil springs cut into the isolators, as seen in the pics below. I even took a pic of the driver’s side control arm which has a witness mark indicating that the end of the spring was making contact with it, after wearing through the isolator. This is just an FYI to others to keep an eye on their isolators, as it could lead to unwanted noises.
I‘ve ordered all new isolators and I’m considering knocking off the sharp edges on the tops and bottoms of each spring and touching them up with a rust inhibiting paint before installing them. Hopefully this will extend the life of the isolators and prevent what I feel was accelerated wear as a result of the sharp edges on the springs. Please let me know your thoughts on whether this would be a good or bad thing to do to the springs.
Robottrainer
Canada
Robottrainer
They all tear. The one isolator is the same for all S550s. With magnaride the other isolator is a special and costs twice as much
NGOT8R
NGOT8R
Adrian
2019 Bullitt
The new spring isolators arrived yesterday. This time I covered the ends of the coils with some thick heat shrink to add an extra layer of protection and hopefully help extend the life of the isolators.
robvas
MI
Guys used to put electrical tape on them in the old days. Does anyone make a polyurethane isolator for these or not?
NGOT8R
NGOT8R
Adrian
2019 Bullitt
Not for Magneride springs. I think a universal isolator kit can be sourced for non Magneride cars.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
I wouldn't use a universal kit, but surprised no one sells/makes a polyurethane kit for our cars.
NGOT8R
NGOT8R
Adrian
2019 Bullitt
Me neither. I like the way the factory isolators twist-lock onto the spring (up top). The bottom isolator is definitely the weak spot in the set.
