Carbon trap removal, +18 hp ??
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
I assume you arent referring to me. I didn't say anything about hp. The long term fuel trims were +20%. Fact. Theres at least 2 of us that have seen that.
I dont think anyone would ever assume there is a linear relationship between intake tube size and HP on an NA Coyote
You're right, it's not linear.
Let's do some math then:
Let's calculate the CFM airflow for both the 90mm and 98mm diameter tubes, assuming they are both 24" long and have an FPM value of 1,000.
For the 90mm diameter tube:
First, we need to calculate the cross-sectional area of the tube:
Area = πr^2
Since the diameter of the tube is 90mm, the radius (r) is half of that, which is 45mm.
Area = π(45 mm)^2
Area ≈ 6,361 mm²
Now, we'll convert the area from mm² to in² by dividing it by 645.16 (since 1 in² = 645.16 mm²):
Area ≈ 6,361 mm² / 645.16
Area ≈ 9.87 in²
Now, let's calculate the CFM:
CFM = FPM × Area
CFM = 1,000 FPM × 9.87 in²
CFM ≈ 9,870 ft³/min
For the 98mm diameter tube:
Area = πr^2
Since the diameter of the tube is 98mm, the radius (r) is half of that, which is 49mm.
Area = π(49 mm)^2
Area ≈ 7,547 mm²
Now, we'll convert the area from mm² to in²:
Area ≈ 7,547 mm² / 645.16
Area ≈ 11.72 in²
CFM = FPM × Area
CFM = 1,000 FPM × 11.72 in²
CFM ≈ 11,720 ft³/min
Difference in CFM airflow between the tubes:
Now that we've calculated the CFM airflow for both tubes, we can find the difference in CFM airflow between them:
Difference = CFM (98mm tube) - CFM (90mm tube)
Difference = 11,720 ft³/min - 9,870 ft³/min
Difference ≈ 1,850 ft³/min
So, the difference in CFM airflow between a 90mm diameter tube and a 98mm diameter tube (both 24" long) is approximately 1,850 ft³/min, assuming an FPM value of 1,000 for both tubes.
So, if we assume that the CFM values we calculated earlier for the 90mm and 98mm tubes were based on a pressure differential of 10" of water, we can use the following equation to calculate the new CFM values at 28" of water:
CFM at 28" of water = CFM at 10" of water × √(28/10)
For the 90mm tube:
CFM at 28" of water = 9,870 ft³/min × √(28/10)
CFM at 28" of water ≈ 17,570 ft³/min
For the 98mm tube:
CFM at 28" of water = 11,720 ft³/min × √(28/10)
CFM at 28" of water ≈ 20,940 ft³/min
Generally, a naturally aspirated engine produces approximately 10-15 horsepower for every 100 CFM of airflow. So, using this rule of thumb, an extra 1850 CFM could potentially result in an additional 185-277 horsepower (calculated as 1850 CFM ÷ 100 CFM × 10-15 HP).
Now we take those horsepower figures and divide by the 28" of water standard.
185/28 = 6.6 hp to 9.9 hp.
^^ that's what your gaining. I'm too lazy to calculate just the choke point.
ChitownStang
Chicago, North Shore
2021 Mach 1
How is this thread 7 pages now? Pretty simple remove it to get your 10 CRANK hp back (keep the sleeve in will ya?). end of story. :like:
That’s what I’ve been saying!!! 😂
It’s pretty funny thread though, entertained me during a stressful workday
ChitownStang
2021 Mach 1
Area = πr^2
Area = π(45 mm)^2
Area ≈ 6,361 mm²
Area ≈ 9.87 in²
CFM = FPM × Area
CFM ≈ 9,870 ft³/min
Area = πr^2
Area = π(49 mm)^2
Area ≈ 7,547 mm²
Area ≈ 11.72 in²
CFM = FPM × Area
For the 90mm tube:
For the 98mm tube:
Obviously! 😝
RocketGuy3
TX
2021 Mach 1, 2016 Cayman GT4
Help us understand how any person can absolutely understand what another can or cannot feel. I’d love to see that science.
And while we’re at it, what tactile experience is not “in your head”? I’d postulate that human nature dictates that our perceptions are in fact our realities. Does that mean they aren’t real?
Dyno results are the closest thing to empirical facts that are pertinent to this discussion, and likely carry the fewest variables. The rest is a combination of unprovable conjecture and opinion.
Using the scientific method and double blind studies, you can easily validate what threshold of measurable differences a normal human can accurately feel. I don't know if scientists have wasted their time with this particular field yet (but probably), but anecdotes I've seen over the years confirm pretty well that a 10 hp difference in a 470-hp car is completely invisible to your ass dyno. Not to mention common sense. I'll expand a lil more below if you care.
Except if it’s in his head, his mind does work that way…
Placebo effect, brotato.
But mostly because it weighs 4000 lbs. 10 HP difference can be felt in a Miata
I'm pretty certain it has less to do with the weight and more to do with the starting HP. You might feel 10 hp in a Miata because you're starting with (depending on the generation) 100-180 hp.
I think a ~10% hp increase is a pretty generally accepted rule of thumb for what you can feel with the human butt dyno. I'm sure there is a scientific-method-validated number out there for the average person. Whatever it is, it's almost certainly way more than 2-4%. Just like how the human ear can't detect a sound difference under 3dB, or a temperature difference under about 0.5C... on average.
Sometimes people will say they can feel something, and they'll end up being right, but that still doesn't prove they actually felt it. As I was getting at with @MAGS1 , placebos are a helluva drug.
RocketGuy3
TX
I don’t know man my butt dyno can tell if I’m running 87 or 93 octane. I think you can tell more than 10 hp gained. Also that’s wheel HP so the crank is going to feel much more lively. You will feel that especially in a manual. It’s about a 4% increase. Lots of guys get a 93 tune and can few the difference and might only be 25 HP over stock. E85 is more noticeable. If taking out an airflow restriction makes almost 20hp you will feel that.
I'm a bit confused by what you're saying. If you're saying "you can feel more than 10hp" meaning you need more than a 10hp gain to feel the difference (20-25 hp in your examples), then I somewhat agree. But I still think you need quite a bit more than 4% to feel a difference. See my above reply.
EDIT: I would say by the time we're talking about 20+ hp to the wheels, it might start to become noticeable, at least depending on where those gains are, and how much the torque curve is impacted.
SheepDog
Colorado
Dax
Iconic Silver 2022 MACH 1 HP
Meanwhile, everyone in here is driving around with the 2.25" factory exhaust neck down....
You know what does make a seat of the pants difference? Going from a 105mm to a 95mm Pulley on my ESS blowcharger. Did that on Saturday and shit just got real.
Get rid of the trap, leave in the sleeve, and save your money for mods that actually make a difference. Tuning for a larger diameter intake isn't worth the money or time.
rubyredponycar
TX
2016 Mustang GT Premium PP Ruby Red - 1st Mustang
Yes, that’s what I mean. For example while driving your in different conditions and air temps you could easily experience plus or minus 10 hp on a cool day vs a hot day or elevation. That probably won’t be noticeable except extreme cases.
But for a counter point if you can tell the difference between different tire pressures you will definitely notice a 20hp difference.
Jasonb543
Detroit
Jason
1993 fox
I have a thread asking about that specifically and basically got told “it’s not a problem” people run 7s through it, on and on.
still hard to believe there is no dyno or track testing with before/after on that specifically
SheepDog
Colorado
Dax
Yeah, I've been told the same thing by forum vendors, and on a stock or nearly stock application (or even mild boost) Im sure it's fine but no one is going to convince me that on 800+ wheel HP that some power isn't being given up. The factory resonator chokes down again at the outlet where it is welded to the exhaust pipes.
Im waiting on some parts from Beefcake and Lethal, and Im going to fix it on my car. I've only recently found a bolt-on solution that maintains the factory active exhaust axle back section, but replaces everything else facing the motor, without having to weld or fabricate anyting. I don't want to muck up this thread with that, but I will create a new one with results.
shogun32
Northern VA
oh I'm sure there is. But it doesn't MATTER which is the point.
You can spend unlimited funds/time and remove every little niggle theoretical restriction and net nothing useful. Life is about pursuing *USEFUL* improvements.
I got a tune on my GT almost as soon as it came off the showroom floor, not because there was an extra HP or dozen, I did it because the stock drivability SUCKED from the factory and I have low tolerance for STUPID interfering in my enjoyment of the act of driving. Ditto rip and replace suspension, bushings, etc. My F150 wasn't 90 days old before every damper was replaced with Bilstein and lowered 2/4 so it would corner and drive tolerably.
The trap may be ouf of my intake, haven't looked - I got this 2nd hand but given the prior owner is m6G member, likely. But if it isn't, I would remove it for no other reason than to stick a thumb in the eye of the EPA even if it COST me horsepower.
Masturbating to miniscule HP increases is the very definition of pointless exercise.
SheepDog
Colorado
Dax
Plus Im the type that will lie awake in bed, and ponder how Im going to "fix" or "improve" any little silly thing. Not sure how many hours of sleep I have lost thinking about the exhaust neck down, but it ain't zero.
shogun32
Northern VA
and some people are like that. In some cases it leads to useful/beneficial innovation. For the rest, there is Xanax. :)
SheepDog
Colorado
Dax
Power to weight ratio is the defining factor of perceived increase in power. If I have a 2000lb car with 100 hp, and a 4000 pound car with 200 HP (same Power to weight ratio) then by increasing the output of both engines by 10%, they net the same increase in power to weight, and therefore have the same perceived increase in power.
If I have a 4000lb car and add 10 hp with the magic of carbon trap removal, and also have a 2000 lb car that gains the same 10 hp with the same carbon trap removal, the increase in performance (and feel) will be more significant in the 2000lb car.
We are talking about a specific power increase of 10 hp, not a % increase based on the initial output of the engine.
