***Urgent*** Check Clutch Line At Brake Master Cylinder
DrZed
Canada
Cam
2021 Mustang GT PP1 M6
Seems to be mostly an assembly error at the factory. It wouldn't hurt if Ford made the line about a 1/2 inch longer.
Have others had this pop off again after clicking it on? My bud put a zip tie on it...
GT Pony
Pacific NW
Don't recall anyone saying it tried to pop off after fully seating the line. Mine hasn't moved since I seated the line fully to the fluid reservoir. A zip tie wouldn't hurt though.
DrZed
Canada
Cam
Thx... good to know.
m3incorp
Georgia/Colorado
James
2019 Mustang GT Premium with Roush Phase 2, 2017 Corvette Z06, 2018 Subaru WRX, 2015 VW Golf, 2015 Ford Fusion
This reminds me to take a peek at mine.
Mustang gt 2016
Oman
Alex
Mustang gt manual 2016
Can someone take a picture of what is normal and post it ? I have problem with my clutch sometimes pedal feels so heavy after pushing it three times in a row, does this mean air is building in? I also noticed some thump noise when shifting and it might be air in the system that does not allow it to fully disengage. I forced this two weeks back after taking it to the dealership because i couldnt start the vehicle and they replaced the clutch pedal switch. I dont know if the messed something while doing that!! Please help
NGOT8R
Adrian
2019 Bullitt
I'm seeing lots of black residue in my brake/clutch fluid reservoir 3 years later. I suspect it's the Steeda black hose. Anyone else seeing this?
Going to go back to the hard plastic Ford hose. Maybe run a cloth through the Steeda rubber hose see if it's deteriorating.
How long have you been running the Steeda hose? I have one packed away, but I’ve been on the fence about installing it. Will you please post pics of your reservoir with the black debris in it? Thanks
smoke_wagon_6g
New York
18 GT
I deleted that post, no reason to throw shade on Steeda, without evidence. Oddball brake fluid contamination occurs on many cars, I checked. must have been lucky not to encounter it earlier. Brakes and clutch feel fine. I'll flush and not worry about it.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
Pushed mine further up way back in the spring of '18 I reckon.. hasn't moved one bit pardner.
Deleted member 35644
Guest
Holy crap....just checked mine. It was pretty far out. Grabbed it, and got a dribble as I pushed it on. Maybe this is why my clutch has been weird a couple times since May. Glad this thread got started.
wangfuco
Ann Arbor
Kevin
S550 GT PP
Guys, when you replace the hose, maybe with the Steeda kit, remember to tighten the clamp on the firewall side, with a proper clamp! It might be a PITA, but DO IT!
The factory hose is normally loose over the reservoir side, so even when air gets in when the fluid is hot, it'll not reach the master cylinder that quickly. If the firewall side is loose, air goes directly into the master cylinder, and the clutch pedal will sag during the cooldown!
thunderstrike
Montgomery, AL
2019 Mustang GT Premium 6 spd
I put tie wraps on before, but I need to check again because going into 2d gear is getting slightly hard. 23K miles.
350Gen6
MA.
2020 GT350R Heritage Edition
Late to the party on this issues and like everyone else I have the same issue. I understand there’s a replacement line that’s’s longer. Does anyone know if there’s a TSB out on this. It would make the conversation with the service manager much easier. Thanks in advance !
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
There's no TSB. We're on our own.
The longer replacement line is made by Steeda. Ford doesn't consider it an issue.
NGOT8R
Adrian
2019 Bullitt
The Steeda line appears to be difficult to install without risking damaging the supplied clamp down at the firewall be abuse of the limited amount of room to work. That’s why I haven’t installed mine yet. I may take ampnother look at it in the near future to see if I can get it done without any fuss.
