1MeanZ
I'm about to start on a small project that will likely a be a waste of time and yield no power gains, but I like working with exhaust tubing and I'll be getting rid of some pretty common sense restrictions in the factory exhaust so I'm going to do it anyway.
The main focus area is getting rid of the 1 7/8" restriction on the passenger side head pipe where the flex joint is, and the second goal is just to get everything else sized up to 2.5" like the rest of the exhaust. I'll be keeping the stock tri-y manifolds and cats. I'll be carefully cutting the welds on the outlet of the cats at the bottom to seamlessly match to some stainless 2.5" tubing. I'll be using a Vibrant flex joint on both sides and then routing back into my X pipe per the factory routing. Essentially I'm going to make what the factory should have put on these cars originally.
Pictures below are before, and show the restrictive area where the flex joint is. If anyone has done this before or has any guesses to how much power, if any, might be gained I'd like to hear it.
