The same with my GT , no guide lines or center line. The picture that you posted looks like the view i have as well. I have the menu for guide lines. It does not correct the issue.Just to be on a same page I don't have neither the guide lines or center line. Compartment closed, trunk closed, reverse gear engaged.
Good point , on the reverse light. I will check that.What was the service done to your car exactly?
Is your reverse light coming on when you put it in reverse?
That's the reboot then do this:Disconnected the battery with driver's door open probably for half an hour or more. Drove 5+mls. Still no lines
I probably drove 30 mls since I did "reboot" the system. I guess if the guidelines menu option is not even reflected in the menu - they won't work.That's the reboot then do this:
Operation should return after the vehicle is driven straight on a flat/smooth road at 20 km/h (12 mph) or more with minimal steering input for 30 seconds.
They did replace the black cover with badge on the trunk, therefore they did disconnect the camera.What was the service done to your car exactly?
On mine no camera disconnect. The zoom is stuck and will not shut off. The zoom button beeps thats all, when touched.On mine the lines went off when i hit the zoom,and never came back. I have opened and slamed shut the trunk. Checked the camera connection. I have not done a reboot procedure. That procedure i leave for my dealer.I probably drove 30 mls since I did "reboot" the system. I guess if the guidelines menu option is not even reflected in the menu - they won't work.
It stays in zoom even when you shift out of reverse? The car has so many can bus systems and modules it's too much to post here. Sometimes it's fun to figure it out, sometimes it nice the car is under warranty.On mine no camera disconnect. The zoom is stuck and will not shut off. The zoom button beeps thats all, when touched.On mine the lines went off when i hit the zoom,and never came back. I have opened and slamed shut the trunk. Checked the camera connection. I have not done a reboot procedure. That procedure i leave for my dealer.
When shifting to drive , i get the nav screen. Map etc. I like your last line, so true. Your help was appreciated, Tim.:ford:It stays in zoom even when you shift out of reverse? The car has so many can bus systems and modules it's too much to post here. Sometimes it's fun to figure it out, sometimes it nice the car is under warranty.
Yep, it goes right to zoom. I will let my dealer work on it over the summer.So when you shift back into reverse it goes straight to zoom? From what I saw there are a lot of self tests and on your big screen synch resets. It must be a windows system CTL-ALT-DEL LOL
can you post a picture of the rear camera picture on your display? I will compare it then based on the visible GT letters to figure out if my camera did stuck in normal or zoom mode.Yep, it goes right to zoom. I will let my dealer work on it over the summer.
Will try to do so, by the end of the week. Its scheduled for some mod work . I will try to take the picture before the car heads to the shop. Its not my daily driver.can you post a picture of the rear camera picture on your display? I will compare it then based on the visible GT letters to figure out if my camera did stuck in normal or zoom mode.
