Oil Temp
North Texas
Charlie
2016 GT 350 Ox White OTT blue stripes, tech pack
Have a 2016 tech pac with 1600 miles. Driving 70-80 on the freeway in 4th and 5th oil temp is routinely 250, ambient temp is high 90s/ 100. Is that normal?
Spacebird
Boulder County, Colorado
2016 GT350R
Yes. I'm experiencing the the same in Texas heat.
icormba
San Jose, Ca
Jeep SRT8 / GT350R / FocusRS
In 95 degree California Heat I'm just over 220 3rd/4th/5th city and hwy @ over 5000 miles.
Shift
CA
a Ford
Even on days that are in the 90s I don't hit higher than 212 after 30-45 minute spirited backroad runs. I have a base model, if that matters to anyone.
Didnt know you were a forum member. I enjoyed watching your videos, and looking forward to more impressions. Also helps that I also have a base Magnetic incoming.
Jb350
Laurel, MD
Joe
2016 Shelby GT350 track pack
At 70_80 in 4th and 5th your pretty high rpm so yea that's normal, my track pack runs a little cooler but not far off
USMC0341
SoCal
George
2020 Shelby GT500
My tech pack eng oil temp got up to 265 on the freeway this weekend temps over a 100.
Honus
Southern Tier, NY
2016 RR GT350 Tech
Highest I got was 250ish yesterday in 90+ ambient - looks to be in line with everyone else.
nastang87xx
Wisconsin
2016 GT350 Track Pack
96 degrees yesterday, with AC on, 80 - 85 MPH on the freeway in 6th, 2300'ish RPM, 206 - 210 all the way from mid state back to SE Wisconsin. I've seen as high as 225 in stop and go freeway in 90+ degree days when paying attention. I think these ranges are pretty normal. LS's routinely run in those types of temp ranges too so whatevs. On autocross, I've seen as high as 240 on a sticky hot day and because of the lower speeds involved, cooling isn't as effective.
My '11 Coyote always ran super cool. I rarely saw over 212'ish in stop and go traffic on my Aeroforce gauge.
Tomster
Beware of idiots
Tom
Mine runs 220 all day long hot or whatever. Goose it and drive it hard in the 90+ degree heat and you will see it in the 240-250 range. It comes right back down when you ease off on it.
superman07
columbus ohio
2016 gt350
I wash my car pretty often, always gently clean out the cooler fins. not sure if that would really matter. I will frequently use up to a quart checking my oil level every 1k between 3k changes.
Have you guys lost a bit of fluid volume?
