Pipefittermax
Any idea how many times you can re-use the oil drain plug. Should you use a new one with every oil change or is the plug good for several oil changes?
What does your owners manual say ?Any idea how many times you can re-use the oil drain plug. Should you use a new one with every oil change or is the plug good for several oil changes?
It should be good. As long as the gasket looks in good shape reuse it. There are some aftermarket plugs but I don’t have any experience with them for these cars. My inclination is to be a little hesitant of something that isn’t oem. Seems like an easy way to get a warranty denialAny idea how many times you can re-use the oil drain plug. Should you use a new one with every oil change or is the plug good for several oil changes?
I didn’t see oil change instructions in the 2021 owners manual. I see they are different now….no longer a bolt, but a plastic plug per a youtube video I came acros.What does your owners manual say ?
I just flipped through it and I don’t see anything eitherI didn’t see oil change instructions in the 2021 owners manual. I see they are different now….no longer a bolt, but a plastic plug per a youtube video I came acros.
I assume the drain plug is reusable for the long term…may be prudent to change the o ring at some point though. I purchased another plug just in case though.
Interesting. I’m surprised it’s any different from the mustang plugI am unable to speak for the mustang as I am still waiting on my order, however the plastic plug on my Raptor has to be replaced every other oil change.
This appears to be one of the better aftermarket options, only concern is one review mentioned the entire plug falling out and the sump losing all oil. Installation error is the most likely cause but its a little off putting to read that. Otherwise nothing but positive reviews for this sump plug.
That’s kinda where I’m at… I’m really interest and like the idea, just tentative when it comes to something where failure can be catastrophic.This appears to be one of the better aftermarket options, only concern is one review mentioned the entire plug falling out and the sump loosing all oil. Installation error is the most likely cause but its a little off putting to read that. Otherwise nothing but positive reviews for this sump plug.
Sitting on the fence as to whether its worth it to move away from the factory sump plug.
I'm thinking something similar about the strut-brace and oil level dip stick right below itAs an aside, there's a special place reserved in hell for the Ford engineer(s) that thought it would be a good idea to run the front sway bar directly in the path of drain oil on the F150s with the 5.0....
