O2 Sensors and fuses
PAD350R
New York
Pat
2017 GT350R
I just had LTH installed and now my car has a plethora of codes, most all indicating that the O2 sensors are not working and the tuner suggested that I check to see if a fuse blew. I don’t see any obvious blown fuses but also don’t see anything listed in the fuse box diagram that might be related. Has anyone experienced this issue?
2023-06-12 12:48:36
2019 Ford Mustang Shelby Coupe, 5.2 L, V8, Ford_TC1791
VIN: 1FA6P8JZ6K5550073
Readiness Monitors
Confirmed Emissions Fault Codes: 12
MIL is On: Yes
MisfireComplete
Fuel SystemIncomplete
ComponentsComplete
CatalystIncomplete
Heated CatalystNot Supported
Evaporative SystemIncomplete
Secondary Air SystemNot Supported
Gasoline Particulate FilterNot Supported
Oxygen SensorIncomplete
Oxygen Sensor HeaterIncomplete
EGR and/or VVT SystemIncomplete
Warmups Since Code Clear: 1
Distance Since Code Clear: 23 Km / 14 Miles
14 Fault Codes Detected
0x7E8 Engine Control Module
P0010SES, Pending, Current
Intake (A) Camshaft Position Actuator Circuit / Open (Bank 1)
P0013SES, Pending, Current
Exhaust (B) Camshaft Position Actuator Circuit / Open (Bank 1)
P0020SES, Pending, Current
Intake (A) Camshaft Position Actuator Circuit / Open (Bank 2)
P0023SES, Pending, Current
Exhaust (B) Camshaft Position Actuator Circuit / Open (Bank 2)
P0135SES, Pending, Current, Permanent
O2 Heater Circuit (Bank 1, Sensor 1)
P0141SES, Pending, Current, Permanent
O2 Heater Circuit (Bank 1, Sensor 2)
P0155SES, Pending, Current, Permanent
O2 Heater Circuit (Bank 2, Sensor 1)
P0161SES, Pending, Current, Permanent
O2 Heater Circuit (Bank 2, Sensor 2)
P0443SES, Pending, Current, Permanent
Evaporative Emission System Purge Control Valve Circuit
P0446SES, Pending, Current, Permanent
Evaporative Emission System Vent Control Circuit
P2004Pending
Intake Manifold Runner Control Stuck Open (Bank 1)
P2005Pending
Intake Manifold Runner Control Stuck Open (Bank 2)
P2008SES, Pending, Current
Intake Manifold Runner Control Circuit/Open (Bank 1)
P2011SES, Pending, Current
Intake Manifold Runner Control Circuit/Open (Bank 2)
Codes Queried from 1 Controller
Report generated by TDN 1.6.10
NGOT8R
Adrian
2019 Bullitt
Are your o2 sensors OEM? I just had an issue with my car throwing multiple misfire codes after installing non OEM sensors. Once I removed those and replaced them with new OEM sensors, the car ran right once again.
PAD350R
New York
Pat
2017 GT350R
Yes, they re-used the OEM sensors from the OEM exhaust. I will double check with the shop, but fairly certain they are OEM.
Thanks.
NGOT8R
Adrian
2019 Bullitt
Thanks.
They didn’t switch them around by chance did they? Mine were two different part numbers.
SlowyoteJay
Georgia
Jay
2019 Mustang GT Premium Non-PP
I don’t know what headers you’re running but with my 1 7/8 catted KOOKS LTH I had to use o2 spacers to trick the system into thinking the cats were OEM since with kooks they are hi flow cats. Have you looked into O2 spacers?
PAD350R
New York
Pat
2017 GT350R
I have not looked into that. Mine are Stainless Works, I believe they are supposed to run fine without. I will will give SW a call and see what they think.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
disconnect the battery both pos & neg for 15 mins. Reconnect, try again.
speedgod
canada
s550 mustang gt
also check your 20 amp fuse on slot 40 that will fix your issue
PAD350R
New York
Pat
2017 GT350R
Thanks for everyone’s advice/help. It actually was fuse slot 42 that was blown. Replaced all is good now.
nolab
Springfield IL
Nolan
2016 mustang gt premium
What kind of spacers did you use?
Frizbey87
Michigan
Kyle
FBO 2020 Mustang GT Premium
Had the same issue but couldn’t find O2 spacers as they’re seemingly blocked from buying if you’re from US, so instead I heard you could use spark plug non-foulers right from O-Reilly’s and a little bit of SOS pad in between that and your O2, threw them in, no more check engine no more code 🤙 for less that 15$
