that looks awesome!My Ford Performance Track Kit lowered the front .875" and the rear .75". It definitely drops it. Thats what I love about this kit, is that it doesn't slam it.
I am also curious as to the answer to this question. It makes sense and might be the way I choose to go. I am torn between going with something like Steeda's minimum drop springs which may not drop the front of my Ecoboost, and upgrading to GT PP1 springs which may actually raise my front (assuming any GT based spring might raise the front?), which I do not want.EB cars are lighter than GT cars, if you use a minimal drop spring with a higher rate, wouldn't that work out similarly as a "no drop" spring?
Do anyone has info on right height for the GT350/R I though this cars are lower than a stock GT PP1 ? If not does that mean that the GT350/R springs are same height as PP1 ?I'd go for the Mach 1 springs rather than the Shelby ones, but basically, you have to choose one of them.
When wisdom speaks, it pays to listen, early and often.I think my final choice will end up closely matching @NightmareMoon first answer right at the start LOL.
wow, a Guard Green?I am still 100% happy with the track handling pack, but as others have said, there is definitely a drop. I'd bet the front is a 0.5" drop on an Eco.
I agree with the posters suggesting Mach 1 or PP1 springs. Might still be possible to find a low mileage take off PP1 suspension.
I think they're about 1/2" lower?Do anyone has info on right height for the GT350/R I though this cars are lower than a stock GT PP1 ? If not does that mean that the GT350/R springs are same height as PP1 ?
Right, but is the R lower because of the tires or because of the springs (or some proportion of both)I think they're about 1/2" lower?
You end up a touch higher in the front when you put aftermarket springs on an Eco, but the rear is essentially the same.EB cars are lighter than GT cars, if you use a minimal drop spring with a higher rate, wouldn't that work out similarly as a "no drop" spring?
Gotcha. I can't help you there.Right, but is the R lower because of the tires or because of the springs (or some proportion of both)
