I’m on E85 now. I have 25 miles to empty can I just add 93 now ?
Unas2k5
Detroit
Samer
2015 Mustang GT, 2021 Explorer ,2019 Impala
If I’m not going WOT and not going high in RPM. I have 25 miles till empty if I just add 93 and drive around slowly it just mix would I be causing damage or do I have to drain the tank? Also for draining the tank, I believe I’m supposed to remove a relay which relay I can’t find that information anywhere?
junits15
MA
Justin
2019 Mustang GT
add the 93, flash your non-e85 tune drive gently for like 15 minutes and you're good to go.
That much e85 will do nothing signifigant, its going to be under 20% total tank concentration assuming 14mpg and actual e85. Which is low enough to where it doesn't matter.
Unas2k5
Unas2k5
Detroit
Samer
Thanks guys I also have a fore dual fuel system if that makes a difference
Andy13186
usually want to keep those submerged as much as possible to lessen the heat. Should try to keep a half tank in atleast most of the time, and I wouldnt go WOT below half or 1/3 tank
Unas2k5
Unas2k5
Detroit
Samer
Thank you for your input. I have never gone under a half a tank of E85. I’m only Going this low because I’m trying to switch fuel and I’m trying to figure out how low I should go before putting in 93
jpjr501
Boca Raton, FL
Joe
2020 Mustang GT - Procharged
You don't want to run the Fore pumps empty like down to 5, not good. At 25 it's low enough.
Unas2k5
Unas2k5
Detroit
Samer
Look 7.3 just driving regular speed limit type speeds lol I’ll probably get like 12 with 93? What do you guys think?
wazslow
PA
2016 Mustang GT/CS
Don't you have a return style fuel system? Just pull the return line at the regulator. Attach a hose to it and pump out the fuel into a fuel can by starting the car. It's easy to do.
Unas2k5
Unas2k5
Detroit
Samer
Ok I figured it out. That’s trip 1 and trip 2 that had different averages. Current one is 7.3 and 15 til empty
HKusp
Hampton, Md.
Jason
Just put 93 in it, flash your tune, drive sensibly for 15-20 minutes and you're good to go. You are over-thinking it.
Unas2k5
Unas2k5
Detroit
Samer
Ok thanks I’m about to fill up I’m at 8 miles to E. I’m also on my E85 pulley and belt I have no choice but to baby it
Unas2k5
Unas2k5
Detroit
Samer
So I put 12.8 gallons of 93 and flashed it. Car when I started it was revving aggressively now it’s starting to calm down ? Is that normal ?
Unas2k5
Unas2k5
Detroit
Samer
No more white smoke I think it’s inhaling the 93 now 😂
LOL WUT
Illinois
19 GT
Yes as the system was still primed with E85 and the ECU was anticipating 93 via the tune. Totally normal for an abnormal start to occur the first time.
Unas2k5
Unas2k5
Detroit
Samer
Alrighty thank you guys! NAPA has full synthetic Mobil one for 6.99!! 5W50 too!
Now I can get a wash and paint correction !
