Has Anyone Installed 3:73 Gears in A Base GT Differential?
Edgemere
Minnesota
Edge
2022 Mustang GT Premium
Greetings,
I have a 2022 Mustang GT Premium with a manual transmission and a 3:55 rear end. It does not have the Performance Package. Just totally upgraded the suspension, and I am loving it.
Has anyone installed 3:73 gears into their base differential? If so how did you like it. I really do not want to spend the money on a Torsen or Wavetrac. I just want more at low RPM's. What did you also do about getting the speedometer to match the new rear end 3:73 gears?
Please advise.
Thanks.................
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
I replaced mine. All beit mines a base '17 300A GT. Going from 3.31 to 3.73 was a night and day difference (for the better). With yours, going from 3.55 to 3.73 you won't notice a lot. I'd go 4.30.
BTW, if your looking for low RPM grunt, you bought the wrong car. Cause there is none.
Rapid Red
Woodstock GA
Greg
3.73 good all-around gear,4.30 quick 60mph 3k ruffly, OP would not like the mpg sporting that tall of a gear, for a DD.
WildHorse
N/A or GO HOME
'17 S550
Dave2013M3
El Segundo,Ca
2020 Ford Mustang GT Base PP1 6MT Rapid Red
Greetings,
Please advise.
Not big enough of a change to make it worth it. As long as you don't have the 3.15:1 pumpkin you should be OK.
I would move on to a set of 4.09s or forget about it.
After 2019 you will need a tune to adjust for the gears. Up until 2019 you could adjust with Forscan.
Trap
Alberta
2013 Boss 302
Have to agree, while you will notice a slight difference with the 3.73, the 4.09's would definitely be the better choice.
dpAtlanta
Atlanta, GA
2019 GT350 (#K2503), 2017 Cayman
I had Ford install 3.73 gears in my Mustang…. It was very expensive…!!!
dpAtlanta
Atlanta, GA
Lots of mods are very expensive. The question is, was it worth it?
Yes….!!
Ford charged me a little over $63,000 for the OEM 3:73 gears, but threw in all the rest of the GT350 parts and the labor.
MrMike
US
16 Mustang GT, 23 Bronco Wildtrak
Please correct me if I'm misunderstanding but I thought it was easier to swap the whole pumpkin than to change the gears.
At a minimum, you have to drop the rear sub-frame to remove the diff cover, correct? Pretty sure you're better off removing the diff from the car to do the work.
qwert7699
Chino California
Liam
2019 Mustang GT
I upgraded to 3.73 in my 2015 auto car and loved them it pulled hard. But my 2019 manual is boosted and has 3.73’s I can’t wait to swap in the 3.31’s I have laying around because I want to stay in boost longer
