Forscan Question - Kam Reset / Crank Relearn ?
WD Pro
United Kingdom
Lime GT
Hi,
Can Forscan be used to do Kam reset and the crank relearn I keep hearing about ?
Cheers,
WD :like:
WD Pro
WD Pro
United Kingdom
Lime GT
Just renewed my ForSkin license :like:
So is the second option the KAM reset option ?
Cheers,
WD :like:
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
So does ForSkin support the crank relearn procedure? I'm curious myself. On the Ford IDS it's called "Misfire Monitor Neutral Profile Correction"
But yes, reset all adaptations should clear all learning memory.
guitrflip
Glendale (818)
Jason
2017 Mustang GT Premium
I'm in need to reset as well, just confirming this worked for you?
Cheers,
WD :like:
WD Pro
WD Pro
United Kingdom
Lime GT
I haven’t had need to try yet :
The KAM reset has been done (a few times) by disconnecting the battery.
The crank relearn was something I still want to know, but it was a question for the future rather than something I needed to do imminently :like:
WD :like:
guitrflip
Glendale (818)
Jason
WD :like:
So, I actually used FORSCAN - PCM Reset All Adaptations and now my car won't start. It's pretty much dead and the BSM kicked in. I'm not sure what to do next besides taking it to the shop.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
USE your As-Built DATA back-up. I assumed you saved it , right ?
OP: No KAM reset w/ FORscan.
guitrflip
Glendale (818)
Jason
I did save my log just in case before i attempted. If Battery Saving Management system is on would i be able to import it back into the car?
WildHorse
N/A or GO HOME
'17 S550
99.9% sure yes.
