fmc_smt
- Jun 4, 2018
- Cottonwood , Arizona
- 2015 gt , 2015 Escape , 2015 F250
- Vehicle Showcase
- 1
Yes it does , and so does the 2011 . But again here is the manual for a 11
NOTICE: During engine repair procedures, cleanliness is extremely important. Any foreign material, including any material created while cleaning gasket surfaces, that enters the oil passages, coolant passages or the oil pan, can cause engine failure.
NOTICE: During engine assembly do not allow the piston connecting rods to come in contact with the piston cooling jets or engine damage may occur.
NOTE: During engine assembly it may become necessary to check bearing clearances and end play. For additional information, refer to Section 303-00.
NOTE: Before assembling the cylinder block, all sealing surfaces must be free of chips, dirt, paint and foreign material. Also, make sure the coolant and oil passages are clear.
- NOTICE: Verify that the connecting rod and rod cap have orientation numbers cast into them. If not, number the connecting rod and rod cap for correct orientation. Failure to do so can result in engine damage.
Remove the bolts and the connecting rod cap. Discard the bolts.
- NOTICE: Do not scratch the cylinder walls or crankshaft journals with the connecting rod or engine damage may occur.
Use the Connecting Rod Installer to push the piston through the top of the cylinder block.
- Repeat the previous 2 steps for each of the remaining pistons.
- Disassemble the 8 pistons. For additional information, refer to Piston in this section.
- Remove the fasteners.
- Remove and discard the cross-mounted main cap bolts.
- Remove and discard the main bearing cap bolts and stud bolt.
- Remove the main bearing caps (1), the lower crankshaft main bearings (2) and the lower thrust bearing (3).
- Remove the crankshaft (1), the upper crankshaft main bearings (2) and the upper thrust washer (3) from the cylinder block.
- Remove the 4 bolts and 4 piston cooling jets from the cylinder block.
- Record the main bearing code found on the front of the engine block.
- Record the main bearing code found on the rear of the crankshaft.
- NOTE: This chart is for selecting main bearings 1 and 5 only, the remaining bearings will be selected using a different chart in the next step.
Using the data recorded earlier and the Bearing Select Fit Chart, Standard Bearings, determine the required bearing grade for main bearings 1 and 5.- Read the first letter of the engine block main bearing code and the first letter of the crankshaft main bearing code.
- Read down the column below the engine block main bearing code letter and across the row next to the crankshaft main bearing code letter, until the 2 intersect. This is the required bearing grade(s) for the No. 1 crankshaft main bearing.
- As an example, if the engine block code letter is "F" and the crankshaft code letter is "P", the correct bearing grade for this main bearing is a "1" for the upper bearing and a "2" for the lower bearing.
- Repeat the above steps using the fifth letter of the block and crankshaft codes to select the No. 5 bearing.
- NOTE: This chart is for selecting main bearings 2, 3 and 4 only.
Using the data recorded earlier and the Bearing Select Fit Chart, Standard Bearings, determine the required bearing grade for main bearings 2, 3 and 4.- Read the second letter of the engine block main bearing code and the second letter of the crankshaft main bearing code.
- Read down the column below the engine block main bearing code letter and across the row next to the crankshaft main bearing code letter, until the 2 intersect. This is the required bearing grade(s) for the No. 2 crankshaft main bearing.
- Repeat the above steps using the third and fourth letters of the block and crankshaft codes to select the No. 3 and No. 4 bearings.
- Install the 4 piston cooling jets and 4 bolts. Tighten in 2 stages.
- Stage 1: Tighten to 10 Nm (89 lb-in).
- Stage 2: Tighten an additional 45 degrees.
- Install the crankshaft main bearings.
- Install the crankshaft upper main bearings into the cylinder block.
- Install the crankshaft lower main bearings and thrust bearing into the bearing caps.
- Make sure all oil passages are aligned.
- Lubricate all main bearings with clean engine oil.
- NOTE: Lubricate the crankshaft bearing journals with clean engine oil.
Install the crankshaft into the cylinder block.
- NOTE: The oil groove on the thrust washer must face toward the rear of the engine (against the crankshaft thrust surface).
Push the crankshaft rearward and install the rear crankshaft upper thrust washer at the back of the No. 5 main boss.
- Install the main bearing caps and fasteners on the cylinder block and, keeping the caps as square as possible, alternately draw the caps down evenly using the cap fasteners.
- Push the crankshaft forward to seat the crankshaft thrust washer. Hold the crankshaft in the forward position.
- Tighten the vertical main bearing cap fasteners in the sequence shown, in 4 stages.
- Stage 1: Tighten fasteners 1 through 20 to 20 Nm (177 lb-in).
- Stage 2: Tighten fasteners 1 through 10 to 40 Nm (30 lb-ft).
- Stage 3: Tighten fasteners 11 through 20 to 65 Nm (48 lb-ft).
- Stage 4: Tighten fasteners 1 through 20 an additional 90 degrees.
- Install the cross-mounted main bearing cap fasteners and tighten in the sequence shown, in 3 stages.
- Stage 2: Tighten to 30 Nm (22 lb-ft).
- Stage 3: Tighten an additional 60 degrees.
- Check the crankshaft end play. For additional information, refer to Section 303-00.
- Check that crankshaft torque-to-turn does not exceed 6 Nm (53 lb-in).
- Check the piston-to-cylinder block and piston ring clearances. For additional information, refer to Section 303-00.
- Assemble the pistons and position the piston ring gaps. For additional information, refer to Piston in this section.
- Make sure the dimple in the piston faces the front of the engine.
NOTICE: Do not allow the piston connecting rods to come in contact with the piston cooling jets or engine damage may occur.
Use the Piston Ring Compressor and the Connecting Rod Installers to install the connecting rod with the upper connecting rod bearing in place.- Lubricate the piston and ring with clean engine oil.
- Lubricate the rod bearings with clean engine oil.
Once the connecting rod is seated on the crankshaft journal, remove the Connecting Rod Installers.
- NOTICE: The rod cap installation must keep the same orientation as marked during disassembly or engine damage may occur.
NOTE: The connecting rod caps are of the "cracked" design and must mate with the connecting rod ends. Excessive bearing clearance will result if not mated correctly.
Position the lower bearing and connecting rod and install the new bolts loosely.
- Repeat the previous 5 steps for each of the remaining pistons.
- Tighten the bolts in the sequence shown in 3 stages.
- Stage 1: Tighten to 20 Nm (177 lb-in).
- Stage 2: Tighten to 38 Nm (28 lb-ft).
- Stage 3: Tighten an additional 105 degrees.
- Install the oil pump screen and pickup tube spacer.
- Tighten to 25 Nm (18 lb-ft).
- Rotate the inner rotor of the oil pump assembly to align the flats on the crankshaft and slip the oil pump over the crankshaft until seated against the block.
- Rotate the oil pump until the bolt holes are aligned to the block and install the fasteners.
- NOTE: Oil pump must be held against the cylinder block until all bolts are tightened.
Tighten the fasteners in the sequence shown in 3 stages:- Stage 1: Hand tighten.
- Stage 2: Tighten the bolt (1) to 10 Nm (89 lb-in), the stud bolt (2) to 25 Nm (18 lb-ft), the bolt (3) to 10 Nm (89 lb-in) and the stud bolt (4) to 20 Nm (177 lb-in).
- Stage 3: Tighten the bolt (1) an additional 45 degrees, the stud bolt (2) an additional 75 degrees, the bolt (3) an additional 45 degrees and the stud bolt (4) an additional 60 degrees.
- NOTE: If the rear crankshaft seal retaining plate is not secured within 4 minutes, the sealant must be removed and the sealing area cleaned with silicone gasket remover and metal surface prep. Follow the directions on the packaging. Allow to dry until there is no sign of wetness, or 5 minutes, whichever is longer. Failure to follow this procedure may cause future oil leaks.
Apply a 3.75 mm (0.147 in) bead of silicone gasket and sealant to the rear crankshaft seal retainer mating surface on the engine block.
- Install the crankshaft rear seal retainer plate and the 6 bolts, tighten in the sequence shown in 2 stages.
