GT Pony
- Mar 13, 2015
- Pacific NW
- 2015 GT Premium, Black w/Saddle, 19s, NAV
My theory on the BBQ tick (typewriter tick) has always been excessive rod side clearance and/or excessive crankshaft end play clearance.
Thinking about this some, I have a test in mind that might give more info on this theory. That test is to have someone that definitely has the ticking at idle drive the car up a very steep driveway or hill and stop, let it idle in that position and see if the ticking changes or stops. Or put the front of the car upon some ramps to get the front end pointed up pretty good so see if the ticking at idle changes or stops.
Doing the steep hill or the steep ramps would make the rods and crankshaft shift towards the back of the engine with gravity and keep them there instead of moving around side-to-side (if that's what they are doing to make the ticking noise), and that would possibly change or stop the ticking if it's caused by excessive rod side or crank end play clearances.
Anyone here with a distinct BBQ tick at idle that wants to try this out and report back what you hear?
