What do you normally with the E85 that you tested in the test kit tube?
SheepDog
Colorado
Dax
Iconic Silver 2022 MACH 1 HP
100% well worth it! love that thing!
Yessir. I have since adapted it to my return fuel system with the Aeromotive Sensor adapter. This allows you to run up to a -10AN line in and out, and has a bypass that flows all aditional fuel around the top of the sensor
Golgo69
Herb
2019 BULLITT
interesting.....my sensor is circled, and my return fuel system (fore) is on the other side like yours, but I still don't understand what you've done.....
SheepDog
Colorado
Dax
I have the Lethal stage 1 fuel system. I decided to install the sensor/adapter in the fuel line that goes from the Driver side fuel rail to the pressure regulator. This is an -8AN line. This photo shows it installed completely with the strut tower brace in place. I used the bracket that came with my pressure regulator, and drilled 2 holes in the plastic "Powered by Ford" cover thing to support it. You can't see that part under the Strut Brace.
SheepDog
Colorado
Dax
@Golgo69 , does your fuel system use the OEM feed line as the return line?
SheepDog
Colorado
Dax
Golgo69
Herb
2019 BULLITT
I see the plug/connector for the bluetooth dongle, but where is your Ethanol sensor installed?
Ha! That's a good question, and sense I didn't install it or know what it looks like I couldn't tell you
