Buldawg76
- Jan 11, 2022
- Alabama,USA
- Mike
- 2020 Ecoboost Premium, 76 Harley shovel, 77 KZ1000
All the mods you are going to do will make it a much more fun car to drive. You don't need to get new charge pipes to install the IC but they add some under hood looks over the stock piping. If you reuse the stock charge pipes then do as @markayash states and remove the retaining clips from the IC end of the rubber hoses that secure the clamps to the hose so you can index the clamps for easier access when installing. You will need to remove the front fascia to install the IC easier.I appreciate the input. I’m just looking to do a mild upgrade. Turbo will remain stock so an IC, piping, turbo back exhaust, and a tune will most likely be as far as I go for engine mods. This will be a daily for me until my daughter is old enough to drive so I just want to give it a little more pep without going full build.
Are the CV piping options good as well? And forgive my ignorance but is the 2.3 MAF or MAP based? Any issues with VTA BOVs?
The eco motor is a MAP based system so no MAF to deal with in intake tube just a MAP sensor in the IC outlet and a MAPT in the top of intake manifold.
Since you have are getting a 2017 I would also suggest looking at the ford performance tune since it includes a trans tune as well (auto trans) and does allow for you to return to the stock calibration from the program, 2018+ FP tune does not allow return to stock except by dealer. The only downside to the FP tuner is it includes a GT350 style open element air box the does not seal well to underside of hood so it will allow for increased IAT1 temps but the stock air box flows plenty well with just a drop in free flow filter.
https://performanceparts.ford.com/part/M-9603-M4
Cobb tuners are also very good and do allow for custom tunes.
BD
