Steeda Upgrade Kit: A Stronger Front Hub & Knuckle For Better Handling!
bnightstar
Bulgaria
Hristofor
2013 Ford Fiesta 1.25i, 2017 GB Ford Mustang GT PP Premium
any plans on doing the same for the rear :?
Biggsy
MD
Warren
'17 GT PP, '10 Tundra
tj@steeda
tj@steeda
Timothy
I'll have to ask our tech team that supported the development.
Best,
TJ
Bluemustang
2015 Mustang Base GT
What are the details of the improved geometry?
Biggsy
MD
Warren
tj@steeda
tj@steeda
Timothy
Still under review - lot of projects in the works, once I hear more, then i'll let you know!
TJ
MrMike
US
16 Mustang GT, 23 Bronco Wildtrak
I installed this kit this weekend. Also replied to an email thread I had going w/Steeda, but wanted to bring it up here in case anyone else is doing the same.
The bolt that holds the front ABS sensor has changed and is not included in the kit. It was a 10mm now it's an 8mm. Not sure on the length or threading, but I had extra bolts around that fit. I think they were for the rear brake dust shield.
kz
West Chester, OH
Mustangs & F150
Are you absolutely certain new ones were 8 mm and not 6 mm ? Did Steeda figured out P/N for those bolts ?
MrMike
US
To be clear I'm referring to the head and not the length of the bolt. The rear brake dust shield bolts have an 8mm head.
Steeda did not get back to me aside from saying they'd let the team know.
kz
West Chester, OH
Mustangs & F150
Oh - that may actually work out - since size is major diameter of the shank, not the socket you use for the head. Thanks, that's helpful !!
tj@steeda
tj@steeda
Timothy
I will get this addresses for you ASAP.
MrMike
US
It's all good, I got mine setup since I had extra bolts from a brake job. I'd just be concerned about any future orders not having those bolts.
tj@steeda
tj@steeda
Timothy
Okay, I had my tech team look at this thread & they advised on the following:
Ford’s part system has these bolts(as well as the hub bolts) listed differently. They show them as 8mm x 1.25 x 15mm long. This is not correct, they are 6mm x 1.0 x 16 mm long. We can't give you a proper part number at this point because of the information below.
I don't know if this helps or hurts the conversation, lol but let me know if I can help assist further.
Best,
TJ
