Stainless Power headers bad fitment - is this safe??
huracan
Sweden
Johan
Mustang GT 2020
My car just got the Stainless Power headers installed (part number SM15H3CATLG) and the shop said that the fitment is very bad, there is only a couple of millimeters space between the headers and the frame of the car, is this normal?
huracan
Sweden
Johan
Mustang GT 2020
Forgot to mention, my car is of model year 2020 and euro spec (Sweden)
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
Most header companies are hit or miss with fitment. So yea it’s pretty normal.
huracan
Sweden
Johan
Mustang GT 2020
Seems like it, but it is safe to drive like that or do I need to remove them?
Jeff's FRC
Lakemoor, IL
Jeff
2020 Mustang GT
Stainless Power headers usually known to fit well. If you loosen both motor mounts, you can shift the engine from side to side slightly. Not sure how the Euro spec cars are, but it's commonplace to have to remove the passenger side A/C line bracket and stud.
huracan
Sweden
Johan
Mustang GT 2020
Thanks for the tips, told the shop and they will try it tomorrow!
huracan
Sweden
Johan
Mustang GT 2020
The shop is not having any success in moving them.. Any expert who knows if that is normal to have it so close to the frame or is it dangerous / possible fire hazard?
jrsimon27
Outside the USA
Mustang GT 2016 PP
They will hit the frame from time to time and you will get false knock i would take them off it doesnt seem safe and i would try to get my money back. Maybe Euro cars are different.
I Bleed Ford Blue
North East OHIO
I have clearance on mine, but I also have a 17 and it's a US spec car. I just found out recently that the stainless power brand is made in China, that could explain the poor fitment.
Jeff's FRC
Lakemoor, IL
Jeff
2020 Mustang GT
Are they actually hitting the frame rail? All these aftermarket headers sit real close on the passenger side. Mine are probably 1/4”-3/8” away from the frame and it’s never hit or caused knock.
huracan
Sweden
Johan
Mustang GT 2020
I dont know.. I havent driven the car yet since the install, its still in the shop.. I have reached out to Stainless Works for a comment but they have not responded yet.. :headbang:
NGOT8R
Adrian
2019 Bullitt
That’s too close and the header primary will definitely hit the frame during engine torque-over. I suggest having the shop mark off the area where it would make contact with your frame, remove them, heat them up until red hot and then lay a piece of flat 1/4” thick plate across the primary tube and put it in a large vice and tighten it down to crush/dimple the primary tube and get at least 1/4” - 5/16” clearance from the frame. Here is what good clearance should look like.
huracan
Sweden
Johan
Mustang GT 2020
Thanks for the pictures.. Yes that looks like a bit more clearance..
NGOT8R
Adrian
2019 Bullitt
If you’d like to save some coin, have the shop remove the headers and do the modification (crush/dimple them yourself) and then take them back to be reinstalled. If you do it carefully, it’ll look very neat and factory. I didn’t have to do this on mine, but did research it. There’s an article online which confirmed that crushing/dimpling the header primary tubes did not negatively affect performance.
With them being so close the inner frame rails is that you may experience a bit of noise/vibration when the engine is running. LT headers also get extremely hot and if anything is near them, you risk melting plastics/harnesses etc. and you also do not want any A/C lines being that close to a header. I recall seeing in other SW LT threads on here that folks had to tie up the A/C line away from the header.
The other issue is as said above, under load the engine wants to “twist” and with barely any space between the primaries and frame as seen in your images, there’s definitley going to be contact under load.
There’s quite a bit of under hood changes done to the Euro cars when they swap the driving positions from US spec to Euro spec. That has to be taken into consideration for any such header mods.
Did the part listing for those headers state they were compatible for the Euro S550’s?
I would reach out to the manufacturer by phone or email, tell them of the issue and send them the same pics:
https://stainlessworks.net/
