Simple plug and play speaker replacement recommendations
ronnyek42
United States
Mustang GT pp2, 2023 Bronco Wildtrak, Ram 3500
Let me first start off by saying I didn't buy this car to listen to the radio... And I'm definitely not an audio phile or anyone who wants subwoofers.
That being said, my 2018 with the bigger sync setup (401a package?), the speakers have next to no bass.
I'm hoping someone could recommend some speakers I can drop in, and hopefully add just a bit more bass (don't need a subwoofer)
I'm mechanically and electrical inclined, but I know nothing about speakers
Or how to order etc.
So anyone have recommendations that would make them sound more like your typical OEM stock speakers? These are a joke 😁
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
Turn off the EQ with forscan first and re-evaluate the situation. You may be satisfied with no other parts.
sms2022
Detroit
SS
2022 Mustang GT PP1 premium
What module is this in? APIM?
Vicr
Fortuna Foothills, AZ
Vic
2015 Mustang Ecoboost Premium
Tycoon
PA
2018 Mustang GT Premium
I don't believe this is possible. Check my other posts to see how to make a 18 system better. Quite a project. Changing the speakers only will increase white noise and will not even sound better.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Sound treatment is what you need. Dropping in speakers will make no noticeable improvement and will most likely make it sound worse. The issue is the OEM amp and tuning.
Adding sound deadener to your doors will improve bass response quite significantly and can be done at home.
joe603
ATL
Joe
2021 GT Premium PP
No free lunch with this stereo...my last straw was after I added a dual 12 sub box with an external amp and tried listening to it with the windows down. Mids/Highs just couldn't keep up with the sub. I ended up replacing the entire system. There are numerous posts on what some (including myself) have done with varying degrees of complexity.
joeyvaz
Saint Cloud FL
Joe
2021 Mustang GT
Agreed with all above. Even after dropping in Hertz speakers in every location (with a Dynavin 8 headunit swap) I was having issues with rattling. I used kilmat on the doors extensively. I actually had to remove my passenger door panel 3x to find one particular rattle. This helped the sound so much, I would not recommend anyone to bypass this step. A rattle can sound like distortion, so I was not happy until I found it and fixed it. In my case, I cut strips of kilmat and put it around all switches, plastic pins, etc. Now the panel is dead silent and has increased bass response form the lower 6.5" mids.
xl_cheese
Wes
2017 GT Premium
