Shifter Vibration in Second Gear
Rags
United States
F150
Is this whole procedure for checking the shifter collar and the O-rings doable for a novice inside the car without taking anything apart that cannot be put back together easily? I've had this vibration in the upper reaches of 1st gear and mid-to-high RPM 2nd gear since the instant I got my car. 100% reducible by pushing the shifter firmly to the right when in 2nd. I want to try this on my own rather than taking it to the dealer but don't want to get in over my head.
I like others have this same sound. And like Blue, I'm not knowledgeable nor have place to do the skunk works above. Would a dealer be willing to do such a check.
dkbluedevil
South Florida
2016 GT350 Track Pack
I am dropping mine at the dealer tomorrow morning and will report back. Service advisor got a quick demo ride with me tonight and noticed the rattle immediately, so I think they understand to examine this first.
dkbluedevil
South Florida
My dealer installed an entire new shifter assembly, PN 7210-D. I was told there was a new design. It improved the rattle by I'd say 80%, which is very very nice. Also seemed to tighten everything up about the shifter movement. Had a little trouble getting into first right at the beginning, but otherwise since it's an improvement. I recommend letting your dealer change it if you have the same issue.
Caballus
Europe
GT350
Bump--
Anyone have recent news/experience with second gear rattle. Have a dealer appointment for Tuesday to look at that and a few other items. Any updates appreciated.
Rimox51
NYC
Richard
2016 Shelby GT350
Mine rattles/vibrates. If I pill up on the reverse lock out the vibration disappears.
Yes cars rattle ...but this is a bit annoying.
65sohc
Fresno, CA
2016 GT350
Dealer replaced mine yesterday. The noise is gone and it indeed shifts better. Ford revised the design last spring. I may be imagining this but the throw seems slightly shorter. What I'm not imagining is that it feels more precise. The first thing the mechanic told me as he rolled up was "this shifter is tighter."
MCarsFan
East
2017 GT350
Bump.
I have this problem on my 2017 late september build. I definitely must have the updated shifter if it was renewed in spring so I m guessing issue is back or maybe its not as bad as it was before?
- People who had their shifter replaced, do you still have some noise?
- Does anyone have a video of what the rattle sounded like before?
DrumReaper
South East
Guys, just do yourselves all a favor and get a MGW shifter! Eliminates all the faults of the factory shifter. [MENTION=19066]Epiphany[/MENTION] can attest.
dkbluedevil
South Florida
My rattle came back within a couple months but I don't care too much about it anymore. Poor design in any case.
I certainly want the MGW eventually but haven't had a good chance/reason to head to GA if they can install it.
DrumReaper
South East
It's not that hard of an install. There's an install video you can watch to get a feel for it.
Julio
France (Paris)
2016 GT350 (Ford Mustang Shelby)
Hi,
I have the same issue, which started at around 8000kms and is now very noticeable in 2nd gear, above 4kRPM.
This is not a "normal" vibration but rather an annoying rattle (my S2000 used to vibrate at 9kRPM but no rattle).
Obviously interested if that can be easily fixed
cz_smidra
Prague
It's a red one.
Hi,
Yep, they replaced the shifter assembly for me at the dealer. It really fixed the problem! For about 5000km :D Now it is back the same or worst :D
My solution is that you get used to it.
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
I have this rattle as well and am debating to have it go in for a new shifter or get the MGW a few buddies of mine have them and love it.
UXXR
Dirty South, USA
2018 Shelby GT350
Reviving this thread from 2016, I just noticed the same very loud vibration on second gear, above 3-4K RPM, while the engine is under load or even when not on load. Third or other gears seem to be unaffected. I do not rest my hand on gear lever. Car is at ~2700 miles. No track time - road use.
It sounds just like "the car did not go into gear" noise, obviously the gear is engaged and car is moving along but vibration makes me cringe.
What are my options here? I can take the gear lever out and check rings but that's the limit of my mechanical options at home. Is my only choice a dealer visit - possible change of gear assembly? That makes me cringe as well.
Also, I noticed Auto Fanatic has a video to fix gear lever vibrations. Is this he same vibration-issue he is fixing??? - I couldn't tell.
Thank you,
