djacowboys
I wanna check that out! Any way that is possible?I was given a 33 page document today.
Which may explain why they weren't flat-shifting in those vids we've seen; I thought the shifts were slow.This is an interesting set of statements.
Looking at the gear ratios and shift points, it seems like shifting at redline will drop the RPM to a level still above the 6250 limit. To me this would imply that you wouldn't actually be able to use the 8250 redline at a track, where straights can often be longer than 8 seconds. Will be interesting to see the actual document and to learn more about how this "feature" works.
It also seems strange that the "trigger/reset limit" for the 8-second window would be 6250 RPM, which is a relatively low engine speed, and much lower than what the Coyote can handle. Finally, it seems strange that iif the over-rev limit is activated, the max engine speed is reduced to 6250 RPM, which is once again much lower than the Coyote.
I could understand the feature if the threshold was 7000 RPM (which is the implied redline when warmed up) since every shift would reset the 8 second window, but as it stands now, with the 6250 limit, I don't see how you could run even a 1/4 mile without triggering this effect. Therefore, something here isn't making sense. My guess is that the 6250 limit only applies while the engine is warming up. Once warm, I would guess that the limit is 7000 RPM. Hopefully several of the 6250 limits are incorrect and should actually be 7000. If so, then this feature will probably not be limiting much at all.
-T
The feature could have been removed for media testing, ride alongs etc... After all it's only a program in the ECU. Similar to GM with the C7Z. Place a restrictive factory tune causing people to tune the car and void warranties preventing future losses. It makes sense considering how hard most of these cars will be driven.Something's just not right here. Ford's not going to produce its "most track-focused vehicle ever" and prevent it from running flat out at the track. There were plenty or reports of the cars hitting the redline last week from the media preview at Grattan. Several of those guys actually know what they're doing, and many of them are racers. Don't you think at least one of them would have reported something strange about the way the car revs - especially since Ford is pushing so hard to promote the 8,250-rpm redline?
-T
Back to the GT350 ratio info, I've got a fun little excel file I made for such things a while back:
I agree with this. Possibly the 8 second timer is only activated if you are holding the car at a constant rpm in one gear, not if you are accelerating through the gears. Or there's some other factor missing / unclear in the statement.Something's just not right here. Ford's not going to produce its "most track-focused vehicle ever" and prevent it from running flat out at the track. There were plenty or reports of the cars hitting the redline last week from the media preview at Grattan. Several of those guys actually know what they're doing, and many of them are racers. Don't you think at least one of them would have reported something strange about the way the car revs - especially since Ford is pushing so hard to promote the 8,250-rpm redline?
Only the R. But I agree, I only think this will come into play if you are doing top speed runs and/or have a track with really long straight aways.^ Not related but aren't the rears 315?
A decent lap around VIR is about 2:08. Without digging out my traqmate data, about half of that is spent at WOT. We spend about 10 seconds in fifth going up the back straight at VIR before hitting the brake zone.Well how often does anyone hold redline for more than 8 seconds?
Where's our copy?I was given a 33 page document today.
I'm confused. Who said anything about WOT?A decent lap around VIR is about 2:08. Without digging out my traqmate data, about half of that is spent at WOT. We spend about 10 seconds in fifth going up the back straight at VIR before hitting the brake zone.
Let's not confuse WOT with holding at red line. I'm sure it will be made clear.
Agreed...and not that I know "jack-crap" about racing...I just watch it on TV..lol but the peak HP and TQ are at around 6,500 RPM right?..so why run it up to 8250 for power..I thought it was just a cushion (if you will) for the shifting...hope this makes sense...:shrug:Most people couldn't handle this car at 8250 for 8 seconds. Riding this snake will be like riding a bull at 8250
