Raise Rpms in Launch control?
jrsimon27
Outside the USA
Mustang GT 2016 PP
Hi friends my gt 2016 has from 3000rpms to 4500rpms in the launch control i see newer models 2018 up have it up to 5500rpms. How can i raise it up? Will a tuner be able to do it? Or with forscan can you do it? Has anybody done it?
Thanks in advance.
1bad66
Soddy Daisy TN
'18 Mustang GT PP1, '66 Mustang, '18 BMW X3, '97 Tacoma
Hmmm, my '18 PP1 car has a 4500 rpm limit in Launch Control.
Shifting_Gears
South Florida
Probably only way is to request it from a tuner to be built into a custom tune.
Honestly LC is not the most efficient way to launch a car. A skilled driver will produce better results not using LC. I think of it as a great tool to use when bored at stop lights and it is fun to just burn the tires down using it.
Dana Pants
Burlington MA
Dana
2018 GT PP1
yep. I file launch control under things I tried exactly once. It’s dumb and bad. You have to literally dump the clutch and if you try to regulate traction with the clutch it goes right to 2000 rpm and bogs.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Just looked at a manual tune and the settings can be changed by a tuner, or yourself if you have HP tuners software.
