green97probe
- Mar 21, 2019
- Monongahela, PA
- Jim
- 2018 Mustang GT, 2014 Edge
- Vehicle Showcase
- 1
Vehicle: 2018 Mustang GT
Trim: 300A
Transmission: MT82
Built 03/18
I recently purchased the touchscreen and APIM from a wrecked 401A 2023 GT to install in my 300A 2018 GT. The installation went smoothly using the 4" to 8" conversion harness from Hellhorse. I corrected the hazard operation via Forscan and have enabled the drive modes.
However, only Normal and Drag Strip modes work. When I toggle to any of the other modes, I get a "Drive Mode Selection Not Available" message on the cluster.
Here are the changes that I made in Forscan:
Enable drive mode toggle (part 1)
ABS 760-02-02 xxxx 3x (GT without Performance Pack)
Enable drive mode toggle (part 2)
IPC 720-06-01 xxxx xxxx x8
Fix hazard toggle operation:
BCM 726-29-02 xxxx xxx0
Note: I also had to change the hazard from "Momentary" to "Latching" in the BCM.
I've spent hours searching to no avail. Could someone please help?
Trim: 300A
Transmission: MT82
Built 03/18
