Seceda91
Damn! Does it really take that much to compete with the SS? I would think, E85 Tune, headers and exhaust can outgun a stock SS on a straight line, tranny per tranny. Plus, Mustangs aftermarket is huuuuuge compared to Chevys.Based on what I've seen at the track, it takes more than that.
At a minimum, it would have to be a base car with an E85 tune and headers. Stock SS traps range between 114 and 116 depending on traps and transmission. The last intake, E85 tune, axleback 5.0 I saw running was trapping 112-113 on drag radials. A couple weeks prior, in similar DA, a stock SS did maybe 10 runs total and trapped 115-116 like clockwork.
Drag Racing:
-Cradle lockout kit
-Maybe axles (depends on how far you go)
-E85 tune (not everyone wants this and E85 isn't readily available everywhere)
-Headers
Magazine tests prove the track pack suspension is inferior. This is based on the assumption that you're referring to the Ford Performance Pack, not aftermarket components.
Handling:
-Springs
-Shocks/struts
-Anti-roll bars
-Cradle lockout kit
The 6MT Camaro gets a 6060 from the factory. It's a stronger/superior transmission. Currently, I'd argue the A8 is also superior to the Mustang's A6 in terms of gearing and shift speed.
Manual transmission:
-RST + alum. flywheel, or some other clutch combo
-Ben Calimer Stage 1 (pads, welded forks, stop shift, 5th gear cones, his secret sauce)
From my experience, these upgrades are necessary if you want to drive the Mustang like a sport cars. The MT82 is a good transmission, but it has weak points that are prone to failure. I'd need these components to feel secure tracking a Mustang, or regularly taking it to the drag strip.
At that point, yes, the Mustang should be about as fast, and handle as well as a Camaro SS. How much is that? I guarantee you it's more than a 1SS with magnaride, NPP, and your choice of tranny, and labor won't be cheap for all of these components. With the SS, one would also retain their warranty, which IS a thing. Yes, I'm factoring in the 20% discount, but a 1SS with those two options would still be a deal compared to a base 5.0 after mod and labor cost. Personally, I wouldn't buy an SS unless I got 20% off, and I would only consider a 1SS. I also wouldn't buy a premium 5.0.
This is just my perspective.
Tracking or road course on the other hand might be more complicated though since the SS has better tires, lighter weight (Thanks to Alpha chasis), engine, diff, tranny coolers and more power. Then again, I will probably track my cars so no biggie.
With that said, the 20% is a good deal but it's hard to find the exact configuration you want so some just settle. I would probably never own a Camaro (Sorry Mustang fan since I was a kid) but if I did, I would only consider it for performance purposes.. Which means the lighter 1SS with NPP and MRC is all I would ever need/want.
Buttt.. it's never all about performance right now since the 5.0 is plenty fast for me.. and since I LOVE the way the Mustang looks and overall a better car.
