- Oct 7, 2014
- California
- Website
- www.modularmotorsportsracing.com
- Worlds Fastest & Only 5 second Coyote
After exhaustive testing and development MMR is pleased to release our new Rear Camber Arms for 2015-2024 Mustangs. Great features such as 6061 Billet Construction, Genuine QA1 Chromoly Rod Ends and ARP Attaching bolts with Stainless Steel misalignment bushings make these some of the nicest available. In stock now for immediate shipment!
Lowering your Mustang Changes the rear Camber which will cause the inside edges of the tire to wear at an extreme rate when street driven. On the other Hand having an adjustable camber arm allows you to dial in your camber for track days and road racing to acheive maximum grip. Bottom line, if you are looking to drastically improve rear traction and feedback - you need the MMR Camber Arms.
The factory rubber bushings deflect causing large unwanted camber changes, these changes are apparent on corner entry and mod corner with twitchy handling and loss of traction.
MMR uses Genuine QA1 Chromoly spherical bearings on Both ends and ARP Attaching Bolts, this means you will have strong, perfect, smooth and QUIET articulation throughout the entire travel range (unlike those companies that use Delrin or Urethane). Aerospace Grade 6061 Billet Aluminum is used throughout for construction making these arms the strongest on the market and tested extensively by MMR and Used to win NASA Time Attack championships!
The MMR Camber Arms feature easy to use adjusters that allow on car adjustment for perfect incremental changes. Our pinch bolt design eliminates the inner Jam Nut from loosening which is one of the biggest complaints of the other brands.
The MMR camber Arms have the largest adjustment range on the market with +3 degree to -6 Degrees
Unlike other brands on the market, these can be used with Spherical style vertical links to have True Non Binding Articulation throughout the entire travel range!
Easy to adjust on the vehicle
Stainless Steel Mis-alignment Bushings will not rust or distort
Plug and Play (alignment suggested after installation)
No increase in Noise or Vibration
Drastic Increase in Rear Grip
+3 degree to -6 Degrees of Adjustament
Made in USA
Made for street tires all the way to the stickiest of slicks!
Fully Rebuildable
Lifetime Warranty
Fits all 2024+ Mustang GT, Ecoboost, and Dark Horse Models
Made in USA
Fully Rebuildable
Lifetime Warranty
