GhostWolf
- Apr 16, 2024
- Pennsylvania
- Thomas
- 2017 Mustang GT Performance Pack
So I wanted to ground myights via the bolt on the strut tower (took power from knee.of the bolts in the fuse box), bolt feels really tight but i figured it's just tight. Well if snapped. And it snapped down low so I can't weld a nut to it. How should I go about removing it. I'm not sure what's below or around it because of I knew I would just drill it out a bit bigger and then tap a bigger hole and use a different bolt but I'm not sure if it's a nut welded inside of there or if drilling to far in will hit something etc. also I'm not sure why I can't add attachments to my posts so here's an imgur,
