Need advice, best tire size for 9.5 front 10.5 rear wheels?
mediumrare
West Palm Beach
Anton
2019 Mustang GT PP1
Hey guys I plan on ordering a new set of wheels and tires for my 2019 mustang gt pp1 magneride, I am going with vossen hf5 20's and from what I have seen 9.5 front and 10.5 rear should fit perfect for a flush fit, however I am not sure what tire size I need so I need some help. Should I go with a 275 front/295 rear, or 275 front/305 rear? I'd like to go as wide as possible without having to do any modifications and want to have the option to lower the car later without rubbing. I like the sound of 305 rears, would that size on 10.5 wheels create any issues? Do any of these tire sizes require any camber adjustment?
I am completely new to ordering aftermarket wheel/tires sizes and know very little about this topic so any help is appreciated as far as the implications of these sizes, I just want to go as wide as possible without creating any weird issues, the car is a daily driver.
This is the fitment I am referencing:
https://www.fitmentindustries.com/w...rd-mustang-vossen-hf3-eibach-lowering-springs
thanks
mike3105
Cambridge, UK
2018 (pre-FL) manual GT
I got Michelin PS4S in 275 and 295 and there's plenty of rim protection and no stretch. Both were 35 sidewalls. I have heard that different tyres have different sidewalls which can impact rim protection and ride.
EDIT: On 20s in 9.5 and 10.5.
js19
Michigan
Joe
2021 Mustang GT Premium
I would say 275/295 is best w those widths. Also eibach springs are the lowest out there so maybe not the most daily driver friendly.
Also since you have 20’s you may have rubbing issues if you go 35 sidewall with eibachs but I’m not certain on that.
shouldn’t need any camber adjustments. What are the wheel offsets?
mediumrare
mediumrare
West Palm Beach
Anton
2019 Mustang GT PP1
I am planning on getting Michelin ps4s, the offset according to the manufacturer is +25 front, +45 rear. If I do lower the car it would be the steeda magneride compatible springs which are only 1" lower, not sure how that compares to the eibach's. At what point is a camber adjustment needed? Could I do 305 rear without a camber adjustment?
js19
Michigan
Joe
if you’re set on 305’s I would recommend getting a larger 11” wheel for optimal fit and performance. Otherwise, the 305’s on 10.5 would work just fine with only the slightest amount of bulge. However, a 35 sidewall would be preferred in that case versus a 30 to minimize that.
I don’t believe you’re in the territory of needing a camber adjustment and that’s with the drop.
https://www.mustang6g.com/forums/threads/whos-lowered-with-305-35-20s.120197/
check out this thread
NGOT8R
Adrian
2019 Bullitt
I just mounted some 305s on my 17X10 drag wheels and they fit perfectly; no ballooning. Here are a few pics for reference.
19BULLITTwhipple
California
Ramzi
Bullitt 2019
WOW THIS LOOKS AMAZING WHAT IS YOU INSTAGRAM! I have a Bullitt and was looking for a drag setup and I just found it! Would love to talk about your car pls let me know.
JK XLR8
Jupiter, Florida
JK
2021 GT Roushcharged
Have 305/30/20 rear on 10s and 255/35/20 on 8.5s.....obviously not a track car. Lowered on Sportlines, no rubbing, no issues. The 305s on a 10 inch rim do not look funny or bulge etc whatsoever...I will post pics if you would like to see.
mediumrare
mediumrare
West Palm Beach
Anton
2019 Mustang GT PP1
sure send a pic if you have a chance, but I would think the rubbing issue would come a combination of a certain offset
The Demon
CA
Brett
2022 Mach 1 N5809, 2019 Mustang GT Premium PP1
I am staggered but I am Front: 19x9.5 275/40/19….Rear: 20x11 305/30/20.
fmc_smt
Cottonwood , Arizona
255/35/20 front on a 9.5 305/30/20 rear on a 10.5 . Lowered on Eibach sport lines. Alignment set to stock specs no rub and everything flush .
fmc_smt
Thanks
