Low pressure and camshaft codes
mallard8
Charleston SC
Rob
2021 Mustang GT Premium
Consistently getting low pressure code P008A on my 2021 GT. When i accelerate past about 4k rpm it goes into engine management mode and gives me a code something like "Camshaft position sensor A." I've seen some say that a new fuel rail sensor has been the solution and also seen some people say that a new fuel pump would solve the problem. Also been told that it's possible that some solenoids or grounding connections are bad. would love some more insight thanks.
luca1290
Italy
Luca
Mustang GT, Mercedes A250 4Matic (W177)
First, use Forscan to check the pressure reported in the fuel rail.
If it's always constant then it's a bad sensor (shorted or clogged), if it's too low after you put some load to the engine probably a bad pump, or clogged filter (which is part of the pump).
mallard8
Charleston SC
Rob
Thanks for the suggestion!
