Harmonic balancer removal
Jay-rod427
Kansas
2016 GT C/S
MAF makes a flywheel holding tool, but you have to take the starter out to use it. Which if you've ever done you know what a glorious !@#%#&^&#%^^%&$%^%&@$% the starter is.
I was able to put a prybar across the water pump bolts and surprisingly the belt held tight enough to torque it to 120.
nrm101
Mass
Nathan
2019 Mustang GT Premium
Ok question guys, i'm able to get the bolt trick on but how much force does this need, i tighting down so much i'm just spinning the block, i don't think impact is the right move so how hard did you have to spin it to get it to start moving???? I feel like i'm good and on straight as i can be with puller, just nervous i guess to put so much force on it. I'm manual and do have it in neutral
SheepDog
Colorado
Dax
Iconic Silver 2022 MACH 1 HP
Put it in 6th gear, and engage the parking brake
nrm101
Mass
Nathan
SheepDog
Colorado
Dax
Are we talking like put 100 150 ft pounds of torque or more??
Just depends on how stuck it is. Newer cars are easier, but several years of North East salt and corrosion shit can certainly make it harder. Just make sure your puller has a good grip on the pulley and that you have the correct sized end piece or rod that goes inside the crank snout. If you are using something too big, you might be binding up against the pulley.
nrm101
Mass
Nathan
Well this is 2019 with 20000 on it. And it doesn't see snow, hence why in a bit abrehensive hitting it with my purse
SheepDog
Colorado
Dax
What tool are you using to remove it?
nrm101
Mass
Nathan
SheepDog
Colorado
Dax
nrm101
Mass
Nathan
This did it, thanks once the motor stopped spinning it started to move, note for others it's going to feel like your hitting 80+ foot pounds every crank on a standard 1/2 rachet till it comes off
nrm101
Mass
Nathan
SheepDog
Colorado
Dax
Do you think this one works better than the OTC 6667 or requires less grinding i guess to make it fit is what i mean?
I didn’t have to grind anything. I would recommend using a rubber band to go around the backside of the jaws to keep them in place while you’re getting them into position into the slots in the balancer.
Jjmoberg
KC, MO
Jeremy
2022 Mach 1 on order
Perfect. Thanks!
