Zrussian13
A pet seal would be dope...
Donāt even think about it! It would wither away into dust out in AZā¦. Unless youāre looking for a reason to build a pool!A pet seal would be dope...
I live in AZ pools are a given! I could use a swimming buddy.Donāt even think about it! It would wither away into dust out in AZā¦. Unless youāre looking for a reason to build a pool!
Right on man. I wonder if a check valve would make it go away? I donāt know that I will mess with it either, even if a check valve did Iām not sure it would be worth the added resistance.I fully embrace the seal.
From what I have been able to gather, that sound is simply the fuel system priming and moving the regulator diaphragm. It doesnāt do it every time and the system has shown no ill effects thus far.
I had the same thoughts. Iād imagine a check valve would eliminate the noise but I am not sure the outcome is worth the effort.Right on man. I wonder if a check valve would make it go away? I donāt know that I will mess with it either, even if a check valve did Iām not sure it would be worth the added resistance.
I don't. I'm stage 3 without rails. You could try getting some big zip ties or make a small metal strap to secure it.Since we have a few Arcane stage 3 folks in this thread, quick question - I got that Y adapter pretty well sandwiched in the driver wheel well between that plate and the body of the car. It seems to be transmitting a bunch of noise into the car. At speed it seems fine, but at idle there is clicking/pulsing sounds. I just assume itās because that Y is making contact with the body of the car. Anyone else deal with this? Or you all probably did a better job routing through that area than I did. Haha
Iām going to take the wheel well apart again, remove the plate and wrap the Y with some insulation tape stuff I found on Amazon. I may shim the plate out with some washers to give it some clearance. Not a ton of wiggle room with all my houses routed in their final place now.
Iām stage 3 using my existing Whipple rails. Oh itās secure, itās tight against the car and the plate. Too tight against the car I think is the issue.I don't. I'm stage 3 without rails. You could try getting some big zip ties or make a small metal strap to secure it.
So, yeah maybe a small piece of foam would work.Iām stage 3 using my existing Whipple rails. Oh itās secure, itās tight against the car and the plate. Too tight against the car I think is the issue.
