Ian whu
Yes mate, I bought lots on eBay , then them to Caniggia.Ian, is that from the guy from poland?
You willing to sell your clears?I've gone the Opposite way, changed my euro lights for USA lights, but had to get them converted with orange Led's
..and the thread in Europe sectionJup, a Guy From poland, check HD-customs.pl
So, I just had a chat with a company that makes the tail light sequencers for the US units.
Here's my logic:
- The "sequencing" is controlled at the BCM. We can't change that (easily) at the moment.
- The inline sequencer harnesses take the brake and hazard signals from the BCM, and re-translate those signals to be a sequence.
- Using that principle, the same hardware can be used to translate the turn signals, hazards, and brake lights to operate in the same manner as the European lights.
- In the reverse, the same can be used to convert the signals on EU-market cars to operate like the US-spec version.
As it turns out, this is an accurate assumption of the technology. However, the company does not currently have the manning resources to dedicate to this right now (understandably, this would fit a very niche market).
The product would of course ideally include the EU-spec plug on one end, and the US-spec plug on the other, so you wouldn't have to manually switch out the pigtails.
So... that's where we are. It's possible, but we need a company to take up the challenge.
Is that what you did? I'm definitely gonna get a set once funds are available.Well, now that the car is FINALLY back, it's install time!
I also created a wiring cheat sheet if anyone is adventurous enough to simply swap the connector end of the wiring harness instead of fiddling around with he internal connector:
No, I had to swap the harnesses like the others only because I couldn't find a clear image showing the wires at the inside ends of the harness. My research is your benefit though!Is that what you did? I'm definitely gonna get a set once funds are available.
Looks GREAT!Well, now that the car is FINALLY back, it's install time!
I gotcha. This is on my must do list!No, I had to swap the harnesses like the others only because I couldn't find a clear image showing the wires at the inside ends of the harness. My research is your benefit though!
