Dragy 60-130
Idaho2018GTPremium
Idaho
2021 Camaro ZL1 A10
Nitromethane not nitrous. Sorry should have clarified.
Some N/A guys will mix in nitromethane fuel. Nitromethane is a crazy powerful fuel because it contains a lot of oxygen but it also has a super low air to fuel ratio which means you have to have super big injectors and a good pump. It’s the fuel they use in top fuel cars. I think they use like 11 gallons in a run.
Ah yes, my brain went to nitrous but I realize what you meant now. How much hp can a FBO engine built w/ nitromethane addition fuel system make over the same FBO engine but on E85?
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
Couldn’t find any good info on mix %, hp, or times when adding nitro.
If we knew the mix % people were running than we could do a good estimate.
The little I could find was people saying that some were spending $20k to build a motor when you could just run nitro mix. So I assume people are making 600+whp stock motor with nitro and maybe cams.
Maybe if I dug harder I could find some more info but not much turned up in my quick search.
GregO
Illinois
S550 GTPP
5% with gasoline and it requires additional additives to mix together.
