DCT TSB Update for leaking/cracked cooler tubes
Epiphany
Global
I like to disassemble things.
Hot off the press. Thanks again B!
Funny thing is I just spent time under the car taking a close look at my own lines. Visual inspection shows both lines are slightly cocked, something every GT500 will suffer from. Anyway, I took some field dimensions and sketched the relevant area just in case a fix is in order.
There is tension at the crimped on flanges as the orientation when swaged isn't where it should be.
Anyway, I have the numbers needed for a potential future project.;)
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
Oooh, Lucky Charms.
So are the dimples in the tab intended to sort of dig into the case and stake it when the bolt is tightened? I'm assuming they are stamped/formed such that up/down orientation doesn't matter when the line is assembled.
(and by the look of it, the axial alignment tolerance must be big enough to drive a truck through)
Epiphany
Epiphany
Global
Yes and yes. Same conclusions from what I see.
Strokerswild
Southern MN
Things With Wheels
No wonder they leak. I think they need new assembly jigs at the line manufacturer.
Epiphany
Epiphany
Global
Cantilevering that flange way out from the retention bolt's centerline is shit engineering, plain and simple.
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
Isnt this the same TSB from 8/21? Thats when it first came out based on the collection of TSB's I have.
gfcobra04
Conroe
Gary
2000 Cobra R, 94 Lightning, 2020 GT500
Was the other tab off center too?
Epiphany
Epiphany
Global
You're right, dammit. Mighty fine collection.
Epiphany
Epiphany
Global
Ford GT. Simplicity and excellence in engineering.
Epiphany
Epiphany
Global
You are thinking about 100% in the right direction...
JCDriller
Kansas
Jerad
97 Cobra, 2001 Saleen, 2003 Cobra, 2020 GT500 CFTP
SPE makes the fix for this, very easy to install.
Epiphany
Epiphany
Global
Honestly not a fan of swapping the factory seal for much smaller o-rings. SPE's fittings don't stop the line from cocking from what their own YouTube video shows either. Anyone see reviews on them?
Tonymustang302
Chicagoland burbs, IL
Tony
2017 Turbo GT, 2019 GT350 racecar, 2021 GT500
mine are arriving today (along with intercooler adapter and hoses). I’ll see what my shelby tech says and thinks
