Canister Oil filter on 2017 GT350R
tdzee
Atlanta Motorsports Park
Tom
85 Corvette, 04 Corvette Z16, 08 350Z NISMO, 15 CTS-V Coupe, 17 GT350R
FL-2062 is correct. I confirmed in my GT350 supplement (revised January 2017) and ordered from Autonation Ford White Bear Lake today. Apparently these filter cartridges are also used on the 2.7L EcoBoost from the F-150.
IMG_8144
IMG_8145
Do we know what size is the wrench nipple?
Bossing
attacks tracks
So. FL
Just can't get enuff!
It's in the workshop manual now:
Hmmm... what size is that hex nut? Here's another pic from underneat... but I'll also check the size when I get under the car again.
Voodooo
SE Michigan
Scott
I went to the dealer yesterday to pick up a few other parts. My parts guy looked this up for me and said it's on back order but comes as a kit.
I had him order me one.
Offboost
Sin City
2018 JR101 Kona Blue R Sold 1/21/19 New 2019;Ruby Red Raptor
So why cant we buy the complete oil filter adaptor housing and bolt it to the block to use the new style filter? I think its not needed but is an option for those that want to have this upgrade.
Spin on filters have been around for years and even with vibration I dont think its really a issue if installec and torqued properly. Hell look at the track attack cars they are not losing oil filters or engines due to filters falling off!
Epiphany
Global
I like to disassemble things.
Believe it or not, this very scenario happened when I attended. Filter came loose, pressure overcame the uncompressed rubber gasket and suddenly blew past. Oil ended up making contact with the exhaust system and created quite a bit of smoke. Many thought it was on fire. The underside of the car was slathered in oil and was pulled from duty for the day.
CasualGuy
Pensacola, FL
2019 Camaro ZL1 1LE & 2013 Focus ST
no it's not....Post #47
new filter p/n HR3Z-6881-A
You do see the photo from the updated GT350 supplement above showing the part number, right?
Offboost
Sin City
Well I stand corrected but I believe that would still fall under improper instalation as the most likely cause.
Tank
9/11 - Never Forget
Above the Notches
G0853
From the first printing of the Shelby Supplemental Manual:
Note: Use only a Motorcraft FL-2069-ST oil filter for maximum performance, reliability and durability. This filter was specifically engineered for this vehicle .
If I recall correctly, the FL-2069-ST, was reported to be a high flow, performance filter. Seems this might not be the case w the canister filter element especially if it's shared across models...
Offboost
Sin City
Ford like many other manufactures tries to save money in manufacturing and engineering costs. In so if they can share parts across model lines then they save money, hence why they went to modular motors shared parts across several designs.
Epiphany
Global
I missed this up above. Unless the threaded filter fitting is simply not used on the latest oil filter adapter casting (allowing this new style canister to simply thread into place) you're right about probably being able to just swap oil filter adapters if the new filter is what you desire.
Tank
9/11 - Never Forget
Above the Notches
G0853
Hey [MENTION=27061]Offboost[/MENTION],
Yes, I can understand that. Just find it ironic...
meares
NC
H4022
the canisters are for cars built in the calendar yr 2017...
the p/n is HR3Z-6881-A
800.367.3788 that's the number for Ford Performance, call them; like i did so I wouldn't be confused with all the speculation on the board...
THX 138
Brownsburg, IN
2016 GT350 Track Pack, 2002 Porsche Boxster S 3.8L
That's the part number for the adapter, not the filter. :rolleyes:
meares
NC
H4022
if that's the case, i stand corrected. i asked the guy on the phone for the p/n for the filter and he looked it up and gave me that number. oh well....sorry to pick a fight !!
