My $.02...Your engine has been designed to use engine oil that meets Ford specification or an equivalent engine oil of the recommended viscosity grade that displays the API Certification Mark for gasoline engines. Do not use supplemental engine oil additives, cleaners or other engine treatments. They are unnecessary and could lead to engine damage that is not covered by Ford warranty.
What's your cold start pressure?Again, read the language. It states the engine is designed to use oil that "meets Ford specification or an equivalent engine oil of the recommended viscosity grade that displays the API Certification Mark for gasoline engines". "Recommended" is the key word here. If the warranty was voided by using something that wasn't recommended, it would be clearly stated.
Truth be told, the reason it isn't stated like that is because Ford knew at the time that Motorcraft (a Ford brand) 5w-50 was the only oil on the market that met the spec, and there are laws that prohibit manufacturers from forcing owners to use only their products.
And the reason I use 0w-40 is because it is a multi-viscosity oil that has the best of both worlds - cold start flow and high temperature viscosity protection. Have you checked your oil pressure on cold start? Have you heard about the oil pump gear failures? I'm not willing to take the risk of an OPG failure on cold start just because Ford wants to save it's own ass by recommending an oil for everyday use that really should only be used on the track. When I take mine to the track, it'll have 5w-50 in it. For the 99.99% of the other time I drive it, it will contain a lower viscosity oil.
Boss 302 owners found out the same thing about their cars...5w-50 is overkill for daily driving.
I'm less concerned with cold start (in the actual cold) and more concerned with the time it takes to warm up. If the OPG is going to fail ..so be it - it's warrantied. That said - I don't plan to drive it on really cold days - decided against running anything but summer rubber. But - on a 40-50deg day - warm up will likely be 10-15min of driving! Already I can drive 10mi on highway before reaching 180...And the reason I use 0w-40 is because it is a multi-viscosity oil that has the best of both worlds - cold start flow and high temperature viscosity protection. Have you checked your oil pressure on cold start? Have you heard about the oil pump gear failures? I'm not willing to take the risk of an OPG failure on cold start just because Ford wants to save it's own ass by recommending an oil for everyday use that really should only be used on the track.
OMFG!!!!! It's the OPG AGAIN!!!!
#WHOSDOWNWITHO.P.G.
HAHAHAHAHAHAHHA
Check your privilege gentleman, people have been banned for less LOL :headbonk:Yeah, you know me!
I've run my car a lot in below zero temperatures. The Voodoo works fine in the cold with the factory recommended oil.And the reason I use 0w-40 is because it is a multi-viscosity oil that has the best of both worlds - cold start flow and high temperature viscosity protection. Have you checked your oil pressure on cold start? Have you heard about the oil pump gear failures? I'm not willing to take the risk of an OPG failure on cold start just because Ford wants to save it's own ass by recommending an oil for everyday use that really should only be used on the track. When I take mine to the track, it'll have 5w-50 in it. For the 99.99% of the other time I drive it, it will contain a lower viscosity oil.
When ambient temperatures are cold the oil doesn't get very warm, no matter how long you run the car. I guess it depends on what you consider "normal". I didn't really like the fact that the oil doesn't ever get up to 180F when the car is run in cold temperatures.Cold start pressure is about 75 PSI, but any off-idle operation immediately pegs it at the bypass at 105. As was stated, it takes 10-15 minutes of normal operation to get the oil up to normal operating temperatures.
Then don't follow my advice. I don't claim to know more than Ford's engineers. But I also don't believe the "recommendation" to use 5w-50 in a street car that was advertised as "the most track capable" car is purely design driven.Believe me, you don't know more about what's best for the GT350 than Ford's engineers do.
The engineers' input was likely limited to answering the question, "Hey, will it cause any harm to recommend 5w-50 all the time?"If there was a good reason to run lower viscosity than 5w-50, they would have us doing that.
I taped off the lower grill and cooler openings last winter and had great results with better temps. Without blocking the coolers, my transmission oil temp would barely get to 100 degrees under any style of driving.When ambient temperatures are cold the oil doesn't get very warm, no matter how long you run the car. I guess it depends on what you consider "normal". I didn't really like the fact that the oil doesn't ever get up to 180F when the car is run in cold temperatures.
