The guy in the video does a good job explaining things but he missed something important that's not in the instructions for any pressure bleeder I've ever seen. BEFORE YOU ATTACH THE PRESSURE BLEEDER, use a turkey baster or some other tool to lower the level of the fluid in the reservoir to the "min" mark or even a bit below. That creates an air space above the fluid in the reservoir during the bleeding process that stays in place above the fluid for the full time you're bleeding. When you finish and gently release the pressure at the canister, the air in the air pocket pushes all the fluid in the bleeder hose back into the canister. It also leaves a reasonable sized air space above the fluid in the reservoir. You don't get the mess of brake fluid everywhere that he got at the end of the process as he was unplugging stuff. It's actually quite civilized if you take advantage of the air space.
Yep, and every time I bleed my brakes, the next time thanksgiving rolls around the corner my wife is pissed wondering where the turkey baster went.....The guy in the video does a good job explaining things but he missed something important that's not in the instructions for any pressure bleeder I've ever seen. BEFORE YOU ATTACH THE PRESSURE BLEEDER, use a turkey baster or some other tool to lower the level of the fluid in the reservoir to the "min" mark or even a bit below. That creates an air space above the fluid in the reservoir during the bleeding process that stays in place above the fluid for the full time you're bleeding. When you finish and gently release the pressure at the canister, the air in the air pocket pushes all the fluid in the bleeder hose back into the canister. It also leaves a reasonable sized air space above the fluid in the reservoir. You don't get the mess of brake fluid everywhere that he got at the end of the process as he was unplugging stuff. It's actually quite civilized if you take advantage of the air space.
You need to bleed your brakes. The fluid is hydrophylic and absorbs water over time. That water can corrode brake parts. You are probably fine, but when you change your brakes, bleed them too. Do yourself a favor and look at the inside pads and make sure they are ok too.Guys,
Thank you so much for all the info. If I dont need to do anything, I would rather wait. Primarily because I dont want to risk of something going wrong during this pandemic. Where I live is pretty restrictive right now.
What is the criteria for changing the pads as well as flushing out the fluid? I dont think there is any benefit of doing this work. Also keep in mind I have another car as my weekend car (C7 ZR1). GT350 is my daily driver + weekend car with family. I dont drive it hard.
I just get ours back in the drawer before she misses itYep, and every time I bleed my brakes, the next time thanksgiving rolls around the corner my wife is pissed wondering where the turkey baster went.....
I don't have my GT350 yet and therefore haven't had a chance to work on it, but from my experience with other cars, use brake lubricant on the back of your brake pads where the pistons contact them instead of anti-seize. Autofantic used antiseize there dampen vibrations from his brakes to quiet them. Brake lubricant is actually made to be used on your brakes so it should dampen vibrations better than antiseize. On top of helping dampen vibrations brake lube will also protect against corrosion, better handle the high temperatures that brakes experience and be harder to wash away because it was designed for that environment. Antiseize is great at what it's made for, which is preventing fastener threads from galling or getting damaged after being left for a long time, but brake lube on brakes is just the right tool for the right job.Hello Forum,
After 59,000 miles, I think it's time for me to change the brake pads. The fronts are down to as much as backing plate whereas rears are a little more. I do have some questions with the procedure and the replacement pads:
- I have read various threads as to what the right way is for doing the pad replacements. Some threads show special tools to spread the pistons as well as the rear hand brake spring. I found one video online which shows a much easier way where he recommends to unscrew the brake fluid reservoir cap and push the pistons out. This also does not require any special tools. Is there anything wrong with this procedure? Is there a better/another DIY that explains this?
- I don't track this car (you can tell from 59,000 miles = stock pads). That being said, I dont know whether I should get different pads or stock. What is the best street pad?
- Some threads I read talks about these bolts and that they need to be replaced. Is this true for someone who will change these pads only every 60,000 miles? Should I get new bolts?
- Why is anti sieze required where blue loctite is on these bolts? Isn't this the complete opposite of what OEM install has?
- How long does the ROTORS last? Can I use them with a different pad than OEM?
Any other suggestions, etc I should know before I attempt this?
Thanks a lot
so the caliperfexion studs will have a corrosion problem? My car is daily driven and that includes plenty of salt and snow driving with snow tires in the winter. So for me corrosion and potential weakness corroded bolts will have is a problem. I am going to keep this car forever (and I mean that, 200-300k miles) and long term outlook is a big factor.Well, if it was me, I'd do what I did the first couple of times I changed my brake pads. I used the 180 mm bolts and I re-installed the factory bolts without bothering to clean them. They're torqued to something like 140 ft-lbs - those dudes aren't going anywhere, even without thread locker. If you're only changing pads every 60,000 miles, then anti-corrosion is more important than convenience, and the OEM bolts are pretty robust. Stainless steel, threaded into aluminum can corrode - which is why I have the steel Caliperfexion studs on my car.
Are you doing rotors too? The rear rotors can be a bit tedious to change, but there are a couple of threads here on tools and techniques that make it simpler.
I experienced corrosion during winter driving on a set of Stoptech's I had a few years back. The caliper studs were stainless and there was a buildup of white corrosion product on the studs where they were in contact with the aluminum calipers. I don't know if the Caliperfexion ones would do this or not - I don't have them - but I went with black oxide coated 4340 steel because of the corrosion I'd seen with stainless.so the caliperfexion studs will have a corrosion problem? My car is daily driven and that includes plenty of salt and snow driving with snow tires in the winter. So for me corrosion and potential weakness corroded bolts will have is a problem. I am going to keep this car forever (and I mean that, 200-300k miles) and long term outlook is a big factor.
I am not doing the rotors as they are nowhere near minimum thickness.
Ok, I'l stick with the stock bolts. Not sure whether I should clean them and reuse or not. Some people say they are torque to yield some say they are not and the reason why Ford's manual asks you discard them is due to the blue stuff on threads and this risk of average mechanic not willing to go through with proper cleaning of their threads.I experienced corrosion during winter driving on a set of Stoptech's I had a few years back. The caliper studs were stainless and there was a buildup of white corrosion product on the studs where they were in contact with the aluminum calipers. I don't know if the Caliperfexion ones would do this or not - I don't have them - but I went with black oxide coated 4340 steel because of the corrosion I'd seen with stainless.
The black oxide studs will rust, so I douse them with WD40 every time I take them off the car - they're fine after three years, although this car has never seen road salt, so that helps.
