• Welcome to Mustang7G!
    If you're joining us from Mustang6G, then you may already have an account here!
    As long as you were registered on Mustang6G as of March 10, 2021 or earlier, then you can simply login here with the same username and password!
roket
Cave Creek, Arizona
roket333.github.io
2024 Ford Mustang Dark Horse
I contacted Livinitup on the 14th gen F-150 forums about how I could create a spreadsheet like his F-150 one with all the parameter names and stuff. Unfortunately, he couldn't tell me how he got those, but he shared with me a link for a spreadsheet he put together for the 2024 Mustang, based on the Dark Horse.
This spreadsheet was not made by me, but by Livinitup on f150gen14.com (thread here)
Link to the spreadsheet
here
roket
roket
Cave Creek, Arizona
roket333.github.io
Here's some stuff that people might be interested in
x = don't change
* = target digit(s)
X = checksum bits (don't change)
Change Speedometer
AddressValue
720-11-01xxx*-xxxx-xxXX
New ValueWhat it does
4140mph speedometer (EcoBoost)
5160mph speedometer (GT)
6180mph speedometer (Dark Horse)
7220mph speedometer (Unused, Broken)
Change Tachometer
AddressValue
720-04-02xxxx-**XX
0A (Imperial), 8A (Metric)Tach Range 1 (6500 redline, up to 8000),
Normal Low Fuel DTE Reminder
0E (Imperial), 8E (Metric)Tach Range 1 (6500 redline, up to 8000),
Reduced Low Fuel DTE Reminder
12 (Imperial), 92 (Metric)Tach Range 2 (7500 redline, up to 9000), Normal Low Fuel DTE Reminder
16 (Imperial), 96 (Metric)Tach Range 2 (7500 redline, up to 9000), Reduced Low Fuel DTE Reminder
1A (Imperial), 9A (Metric)Tach Range 3 (acts like range 2, unused),
1E (Imperial), 9E (Metric)Tach Range 3 (acts like range 2, unused),
02 (Imperial), 82 (Metric)No Tach Range (acts like range 2, unused),
06 (Imperial), 86 (Metric)No Tach Range (acts like range 2, unused),
the reason for the different imperial vs metric values is this data also controls the units the dash uses, most notably the speedometer. the reason why a whole byte needs to be changed is due to binary bad luck. the last bit in one character and first bit in the other both change the tachometer
<post reserved for interesting FORScan codes/values>
Dave2013M3
El Segundo,Ca
2020 Ford Mustang GT Base PP1
Getting there, still missing a ton of functions. Good work...
roket
roket
Cave Creek, Arizona
roket333.github.io
yeah, still more work to do, but we're off to a really strong start considering how new the S650 is
DCS
Ocala, FL
2020 Lincoln Continental Reserve; 2024 Mustang GT
FORScan not ready, according to their website today.
S650 Mustang 2024 Mustang FORScan List / Database / Spreadsheet (by Livinitup) FORScan
roket
roket
Cave Creek, Arizona
roket333.github.io
their latest Windows release supports the 2024 Mustang, but has issues programming the BCMB, LDCMA, and LDCMB
DCS
Ocala, FL
I have no idea what that is as I am new to this device concept. As I have ordered a 2024 Mustang, and it is chock full of electronics, I figured I'd better get up to speed, which is why I have been watching this thread for the best ODBII scanner to buy.
DCS
Ocala, FL
According to their website, the 2024 Fords are NOT supported. I also asked the manufacturer of BlueDriver. They didn't respond. That means no (in my book).
Still looking.
roadpilot
Michigan
24 Dark Horse, 21 F150 Platinum, 16 ATS4, 14 LTZ
I've been using FORSCAN since 2016 on the last 3 F-Series trucks I've owned. I've been using the OBDLink MX Bluetooth Scan Tool (Android and Windows) That's been replaced with the OBDLink MX+ (Android, iPhone, and Windows). If I didn't own the MX, the MX+ would be the only one I would even consider. I do own a Mongoose-Plus J2534 VIC for actually programming all the modules (using FDRS), but there's no reason to spend that unless you also plan on updating module firmware in your Ford vehicles.
DCS
Ocala, FL
As I mentioned, the FORScan software for windows does NOT support 2024 Ford & Lincoln. It’s on their website.
roket
roket
Cave Creek, Arizona
roket333.github.io
yeah, there's probably a lot of unsupported 2024 MY vehicles, but i can promise you the '24 Mustang is mostly supported. i've personally programmed with it on my 2024 Mustang and 2 others, and read data with it on over 10 2024 Mustangs
roadpilot
Michigan
Read through the forums. The current version is working with certain 2024 vehicles now, and it seems like there are working in the direction of adding more. It's not a simple thing.
kneeko
Miami
2024 S650 GT
Just curious Roket what things could I do with ForScan. I don't have any crazy knowledge about this and I was wondering if it was worth it just to add or change some cool things. Is that possible?
roket
roket
Cave Creek, Arizona
roket333.github.io
it really depends on how happy you are with the car to begin with. if youre perfectly happy with how it is factory, then it may not be worth it. if you plan to do things like put on much different size rear tires or put in a new diff ratio then it may be worth it. if you plan to do big things like retrofit heated and/or cooled seats, add power folding mirrors, or give the vehicle approach lighting, as well as experimenting just to see what you can add, its definitely worth it. personally, i fall into the 3rd camp of experimenting and retrofitting, plus i also use it at work if, for example, someone wants their auto start-stop disabled, or the key detection alert disabled
kneeko
Miami
2024 S650 GT
awesome thx u!
