2019 Mustang GT A/T OVERHEATS.
Blue Horse
Mustang GT
  • Thread starter
  • Banned
  • #1
The 2019 Mustang GT/ A T) was not able to complete 2 laps on the track because of overheating,Ford says IT'S NOT a track car,even though it has the track package.Ford states it is designed for street and touring,the car didn't even make 2 laps without going into the LIMP mode.SAD !!!!!!!!!!!!
Zelek
Round Rock / Hutto, TX
2021 Mustang Mach 1
You're right, that's exactly what they said. So go get a transmission cooler and fix it.
NoVaGT
Northern Virginia
2019 PP1 GT Kona
This has been know for many years now.
Blue Horse
Mustang GT
  • Thread starter
  • Banned
  • #6
How could it have been known for many years,this was a 2019 Mustang GT. The last time I looked this is still 2019 !!!
nastang87xx
Wisconsin
2016 GT350 Track Pack
S197 Coyote cars routinely showed nearly 300 degrees in the manual transmission on track but the difference is that there wasn't a sensor that would force the car into limp mode. Hence, these guys were cooking fluid, having to change it out, and still adding auxiliary cooling systems. I believe the 6R80 did track trans temps and would shut the car down if it got out of acceptable limits. Limp mode doesn't always means the car is broken, sometimes it means it's saving itself from becoming broken.
EFI
Masshole central
5.Br0
Drives a torque converter automatic on the track and is surprised that it overheats??
Not once did Ford stated this is a track car, especially with an auto. You want to track the car, well then go get yourself some real cooling.
Zinc03svt
usa
stang
I bet your a dollar OP your a10 trans is under filled. Plenty of others have made it couple times around various tracks without going into overheat mode. If your looking to race it aftermarket coolers would be a must.
marks
Essex
2017 Mustang GT Race Red Manual
The automatics are designed for cruising not racing
Ebm
North Carolina
Guy
'14 GT
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
gt-350r, & new gt-500 track pack are the only track cars for mustangs. You bought street car my friend. when you get a trans cooler in your rear diff will put it in limp mode next track outing. so get a rear diff cooler to...
NoVaGT
Northern Virginia
2019 PP1 GT Kona
The GT350 (non R), all GTs, and really all Mustangs since 2015. Once they put temp sensors in the transmissions, fun at the track has required a trans-cooler. And a diff cooler.
This has been a topic here since forever and a day.
