12 qts or 11.5?
_M_
Planet Earth
A Mustang
What’s everyone doing? The actual 11.5 or you just pouring all 12 quarts in?
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2022 F150 PowerBoost
I used the whole 12 quarts. After I changed the oil and filter the stick was showing 1/2 quart low, so I added the last 1/2 quart.
  • Like
Reactions: _M_
Epiphany
Global
I like to disassemble things.
12 here too.
  • Like
Reactions: _M_
_M_
_M_
Planet Earth
A Mustang
12 it is then. Thanks!
Tomster
Beware of idiots
Tom
Hold your horses.....
I did exactly the same thing, and it still showed about a half quart low.
Run around the track a whole bunch of times, and the oil quantity increased. I'm not talking about thermal expansion. It was a bit low at 12 qts, now it is a bit high. Id put the 11.5 qts in there.
  • Like
Reactions: _M_
_M_
_M_
Planet Earth
A Mustang
Interesting. I can do 11.5, drive, then measure.
Tomster
Beware of idiots
Tom
Make it a very spirited one. I didn't see the increase until sustained high RPM. Its the strangest thing. I never added oil, and then under those conditions, it went up.
Apples to apples, measuring each time when the engine had sat overnight and oil was cold.
  • Like
Reactions: _M_
_M_
_M_
Planet Earth
A Mustang
will do. And what the heck is this plastic shield in front of the oil filter? Is that there just to make changing the oil difficult??
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
12 qts here just got it done Saturday.
Cgouzoulis
chris
None
12 quarts
Tomster
Beware of idiots
Tom
The shield will move just enough to approach the filter from the left wheel well. Yea, not optimal, but it works.
AngelDeath
CH, New Jersey
And all just a little shy of full, right?
Havent looked its in the garage, I'll look Saturday, plus I got on it a bit after the 1k oil change so I'll see what its at.
_M_
_M_
Planet Earth
A Mustang
Got to get a new flexible funnel. The one I have for R is too big. Wont fit under there
Cgouzoulis
chris
None
After driving yes, a bit below, id say 3/4s in between the etched portions of the stick
Edit to add, thats the exact same spot it was from factory
