K4fxd
Have that intake flowed on a flow bench. You want even flow through all tubes or it will be a tuning nightmare.Already working on a project. Will pair with a 95mm soler tb
Well if TD dosn't want it, I'd be very interested. Gotta find a couple tenths.Only way it will mess up now is if the plugs come undone.
Yes sir.
I don’t know how I could flow bench it and then re work it. I cut it apart and will have to reseal it. I know another guy that does this and I don’t think he flow benches themHave that intake flowed on a flow bench. You want even flow through all tubes or it will be a tuning nightmare.
Thank you for the feedback. Getting the maf data sorted is next on my list. Then upping the rpm, getting the cam profiles closer to Lund for wot, adding some timing, then diving into mapped points to see if I need to adjust anything there.Comments on the posted log:
- Your data rate is pretty bad on some channels. You'll need to pare down the channel list, like getting rid of most if not all mapped point weights, and speed up the polling rates on things like cam timing.
- Speaking of cam timing, it looks like the exhaust cams are at 30 at WOT and intake are at -20 the whole time. I don't know what the optimum cam timing is, but in almost every case it is beneficial to retard the intake cam at high rpm. You can pluck a good starting point from your logs of the Lund file.
- I believe this is pump gas. As such, it's knock-adding 8 to 10 deg. That means you're having to wait 2-3 seconds for it to feed in the timing. If this were mine and you intend to stay at this octane level (never less), I would add about 6 deg to the borderline tables and limit knock advance to about 3 and see what that yields.
- It appears to be going into cat protect mode, which is forcing it rich. I don't think you have cats, so there is no need for this.
- The fuel trims being +10% is an indication that your actual airflow is 10% higher than the MAF transfer function thinks it is (assuming the injector data is correct). This is causing the load to log artificially low. If you get the fuel trims closer to 0 up top, the engine load up top won't fall off like it is in the log.
I'd do one port, cut out a template for it, and use it as a guide for the rest. That's how I do aluminum intakes. Never flow tested, works great.I don’t know how I could flow bench it and then re work it. I cut it apart and will have to reseal it. I know another guy that does this and I don’t think he flow benches them
It's the difference from being first or an also ran. Use RTV stick it together and get it flowed. Work on the weak cylinders.I know another guy that does this and I don’t think he flow benches them
I’ll make another thread later where we can talk about it more.I'd do one port, cut out a template for it, and use it as a guide for the rest. That's how I do aluminum intakes.
Hmm. JPT got my base tune pretty spot on. I wonder what data they are using. I’ve only seen one set of roush data floating around. I know ford offers it but it’s not in the right pressure and I don’t know how to manually convert itI would trust the MAF since it was provided by PMAS. I never had any luck tuning LU47's using roush data. Thee are at least 3 differing sets of data from them. I like the predator 52's. Ford's data is good on them.
I’ve been working on this boss manifold project for like a year and a half, I can’t give up now![]()
I’ll have to start another thread where we can talk about it. If it’s not super impractical then I don’t have a problem doing itYou can get real close using a wind speed tester like you would for long range shooting and a vacuum cleaner. Would remove the cost of flow testing.
I would use foam weather sealing tape and some clamps to seal the top.If it’s not super impractical then I don’t have a problem doing it
Maybe get to know Bret Barber for that manifold project. Dan is on point, balancing the flow is a priority.I’ll make another thread later where we can talk about it more.
I want to get the tuning good, then either rip the engine apart to find the issue causing it to be slow, or finish the manifold.
