BMR Sways and Procharger Stage 2 Issue
MyLilPony
Naw It's Stock
Prosper, TX
Kris
2015 Black GT, 18 JLUR, 15 JK
[MENTION=9985]BMR Tech[/MENTION] I am hoping you can help me out as this is probably the better subforum to ask the question.
I pried the sway bar forward, still touches. I ground the bar a little bit and it touched again. I took a bit more off again the other day but I am assuming any more and I weaken the bar and put a hole in it.
Lowering the motor IMHO wont work as it will move the issue to the outer edges of the pulley vs. just the lower point.
In your opinion would a solid or firm motor mount like the MM006/007 solve the issue. I don't want to remove the sway bar but also don't want a broken motor because of a cranks snap due to contact with the bar. As a note, the stock swaybar did not have this issue.
Other post with more details on the issue and the entire history of the problem.
http://www.mustang6g.com/forums/showthread.php?t=87026&page=2
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
Hey man, sorry for falling off the subject. Trying to keep up can be challenging.
Can you post pics of the ends of the sway bar where the end links mount? First I want to verify you have the correct sway bar before going further into troubleshooting.
Also, how much further does that PC pulley configuration stick out (towards the front) more than the stock assembly?
MyLilPony
MyLilPony
Naw It's Stock
Prosper, TX
Kris
I get it, not a problem :)
Here are the pics. the pulley stickes out approx 1 3/8" past the stock pulley tried to grab a pic of it as well.
MyLilPony
MyLilPony
Naw It's Stock
Prosper, TX
Kris
Bump [MENTION=9985]BMR Tech[/MENTION]
MyLilPony
MyLilPony
Naw It's Stock
Prosper, TX
Kris
wildcatgoal
@sirboom_photography
TBD
Hmm, maybe they re-did them since the photos available online? When did you buy these? Weird. Looking at this American Muscle video and, yep, they look like your bars (so, yeah, my bad): [ame]
Sorry this is happening. So weird. There's a guy with PC I know with BMR bars and he doesn't have an issue. At least he's never mentioned it.
MyLilPony
MyLilPony
Naw It's Stock
Prosper, TX
Kris
Do you know if it’s a stage 2? On the S2 they add an additional pulley to the main and it adds about 1.5” to the front of the main pulley.
Andrewg
Sun, Sea, Sand and Camels
Dubai, U.A.E.
Andy
2015 Guard Metallic GT 401A
Weird! I'll see if i can get a shot of mine but i'm running the stage 2 with BMR sways and i've got way more clearance. Good half inch to an inch of space between the pulley and the bar.
BMR Tech
Tampa, FL
Dion
