Are you guys using any oil?
Nickel
NC Twisties
www.instagram.com
Nick
2022 Mach 1 Handling Package TR3160 w/Recaros
From what I read before I got my Mach 1, dealerships and people I talked to expected the Gen 3 coyote in this configuration to use a bit of oil, but not on the scale of the voodoo. I did a full weekend (maybe 800 miles) of dragon driving and then a track day at AMP and Road Atlanta and my car hasn't used a drop. I was actually surprised. I was checking it a lot and no usage. Has anybody else had different results?
SnowFox
Mn
Grabber
2022 GT, 2017 ECOboost, Saleen S351
Nope. But If I am its miniscule and I can't tell.
Skye
≈39N
"Skye" Mach1 N2144
Have not lost a drop, in leaks or burning. Two oil analysis have come back nominal.
No modifications to the engine.
Performed what I considered a progressive break-in, especially in the first 100 miles / 160 kms.
First oil change at 1,250 miles / 2,000 km. I use Pennzoil Ultra Platinum, 5W30.
For fuel, Shell Premium, highest octane in my area.
Everything has weathered in well. Have not had any issues or tells that concern me.
luca1290
Italy
Luca
Mustang GT, MB A250 4Matic W177, Mazda MX-5 ND
Mine does not consume any oil. Did a careful and progressive break in.
I do that on any car and none of them consume any oil.
skinnyb
Knoxville TN
Alex
2022 GT Premium PP1, 10 Auto Grabber Blue
Mine does just a bit but not enough to worry about. I check every 1000 miles or so and it has maybe moved a hair. I did the same a couple weeks ago, did a Mustang Rally all over the TOD area and Western NC, 1000 miles total and no usage noticed. I think I put about 4 oz in at the 4000 mile mark last oil change just because I am OCD. But with 10 quart capacity nothing to worry about. That said, my Gen 3 Coyote F150 I had to put a quart in every 2500 or so. Ran it to 100k miles without any issue though, ran perfect...
Hack
Minneapolis
Mustang, Camaro
I think the Voodoo is a special case because it's more likely that people won't use them as cars. I think when a car is babied too much, the rings don't seat very well. Too much idling and/or very little full throttle usage is not good for an engine.
Also, the original Voodoo design rings seemed to be slightly fragile (or possibly there was an issue with the factory installation methods). Ford did a redesign on the rings fairly quickly during Voodoo production.
A third factor in this oil-using reputation - I owned a 2016 GT350 and mine didn't burn any oil - unless I overfilled it. The oil level wanted to be halfway in between the upper and lower marks on the dipstick. If I tried to keep it at the top mark, I could continue adding oil and the level would continue to fall. If I just left it alone at that halfway mark, it would stay there for the full oil change interval. Some people whose engines "use oil" are just really overfilling their engines rather than following Ford's instructions.
I broke in my Voodoo engine with a lot of full throttle and no throttle engine braking at mid RPMs. So I think that kind of initial usage prevented any issues with the rings seating.
Crew4991
Denver Colorado
Crew
2016 Mustang, 2006 Viper
None. Most cars do not burn oil from new.
The only time they do are sometimes the hand built engines OR most likely... the factory built the engine incorrectly to begin with.
Charlemagne
Czech Republic (Europe)
Nick
I didn't notice any oil use in my yearly 3000 miles between changes either. Minimal amount of oil that I pour out of the catch can.
S550VIN54
Raleigh NC
Stephen
2021 FJG Mach 1 HP
I see a slight amount like an oz or less in my catch can about every 5k miles.
cerbomark
TN
20 GT PP2. 24 Ram BTS, 21 Mach1 (Sold)
just a table spoon or so in the catch can, nothing measurable in the first 6K.
TonyT930
Philadelphia, Pa.
Tony
2017 Mustang GT Convertible in Ruby Red
I have a 2017 GT convertible with 29k miles. It doesn't use any oil between oil changes
black22gt
TX
Trigger
2022 mustang gt
None that I can tell. I got a 22 GT with almost 60k. Although I've skipped the pre-check the past couple times, i check before i leave to get the oil change and after its done (but before i drive away), seems to always be the same exact level, which is usually slightly above the middle. I did a motoman break in, so my rings should be sealing up very well (power output also seems to agree fwiw).
