Wiring my flow gauge, anyone know what wire to use for instrument panel lights?
5.0yote
AKA Bananana & 3.7Cyclone
Mansfield, MA
www.youtube.com
Don
2016 Mustang Ecoboost Premium
So I am wiring up a AEM flow gauge for my methanol setup but I am not having any luck finding which wire to tap for the instrument panel lights (dimmer) for the gauge lighting.
Does anyone know or have access to wiring diagram for the lighting switch in the dash? Search is not getting me anywhere.
I would like to have the light be dynamic and not always on or off.
Is it still the Violet wire like previous models off the head light switch?
5.0yote
5.0yote
Mansfield, MA
www.youtube.com
Don
well I was in there and installed my gauge but left the grey wire disconnected, the headlight switch has multiple violet wires I need to find out which wire is the dash illumination one.
Juben
Chattanooga, TN
Justin
2015 EcoBoost Mustang (AT) w/PP
If I remember, I'll try to look tonight or in the morning in the service manual to see if it shows anything. If so, I'll pdf it and send it over to you.
5.0yote
5.0yote
Mansfield, MA
www.youtube.com
Don
Hi, thank you very much do you know if there is a plug schematic available to show which pins are which or is it on the plug itself, I noted in the PDF it is the purple/violet wire like I figured but there are two and I am not sure of the pinout to seperate the one for the panel cluster? I suppose I can just do a process of elimination with the other wires to determine the pin #s
hro0250
Seattle WA
2015 Magnetic Ecoboost Premium
It says on the PDF next to the wire, its pin 15 at the headlight switch. Two over from 15 at pin 13 is the other violet wire which is for the autolamp position, pin 12 is blue so if you see that go 3 over the other direction. It should also say on the plug itself.
5.0yote
5.0yote
Mansfield, MA
www.youtube.com
Don
Yeah I got that just did not notice if the pins on the switch or plug were numbered, so I was going to go by the color pattern of the existing wires to numbers. Gunna splice into that wire this weekend, I can read the gauge as is at the moment it does have a default light level but it would be nice to tie it into the dash.
5.0yote
5.0yote
Mansfield, MA
www.youtube.com
Don
Yup that did it there are a bunch of pins not in use on that plug like pin1, 7, 8, 16 etc. So they were in a row like in the diagram. All set, so much better now that its tied in. Thanks a bunch man.
Greg94
Lakeland Fl
Ecoboost
Just to clarify, you tapped into pin 15. Or did you also tap into pin 13 so the auto lamp feature would apply as well.
5.0yote
5.0yote
Mansfield, MA
www.youtube.com
Don
Auto lamp does not apply in this case as the gauge is "always on" its lowest brightness when powered. Since the brightness will only adjust when the auto lamp feature activates when its dark enough anyway, so its a moot point because when the dash lights come on is when the gauge senses a voltage change for illumination from the violet wire on pin 15 anyway.
If you plug into the wire on pin 13 I think one of two outcomes would happen, either nothing happens and the gauge stays at its lowest brightness setting like the grey wire was never connected at all, or it will go to some sort of brightness level based on the amount of voltage supplied from the signal on the wire in pin 13 but it would not be adjustable. This is because its just a signal being sent to or from the BCM telling the lights to turn on. Nothing more.
So only 15 was needed to tap.
higdominator
Central Oklahoma
2016 GT PPP
I was searching and came across this thread while looking for a way to wire up an autometer ES boost gauge. It has white lettering that turns red when the light is activated. I assume I could tap into PIN 13 so that this gauge would turn red when my other gauges turn red (my color) as well? (when it gets dark).
I can check the voltage of 13 if you believe it is only a small voltage signal and possibly use a small relay to power the gauge light (LED).
monte87
NY-SHITTY
Anthony
2021 Rapid RED Metallic GT
What color wire did you splice Into for illumination?? Thanks Anthony
