DarkestHour
Hi
I was working on my car the other day and discovered this. Both the 13mm bolts were backed out with one about to fall out/completely loose and the other one nearest the blue subframe bolt to be supporting the bracket and also stripped.
It looks like all I should have to do is remove the two 13mm and the 21mm bolt, but I'm unsure the best place to jack the car to support the subframe as so many instructions recommend but don't show imagery for
If anyone also happens to know the 13mm bolt specifications I will also need to go buy a new one to replace the stripped one.
Thanks in advance!
Thanks in advance!
